Thread: Ticking noise, A6 2.7 tdi
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Ticking noise, A6 2.7 tdi
    1837 Post(s)
    Quote Originally Posted by kimlk View Post
    What will happening if I continue to use the car?
    Eventually it will jump and **** a valve or six. The engine you have isn't much use, if you have the skills and facilities, I would pull the box and fit a new set of chains and adjusters.
  2. Re: Ticking noise, A6 2.7 tdi
    Oct 2016
    Norway
    Ok.. Opened up the upper right hand chain cover. Seemed like it was some slack in the chain. Thougt, why not, and changed the tensioner. Started the car up and, presto, new BAD sound. More like a knocking sound. Sendt the car to a garage. The mechanic checked the timing and made shure everyhing was ok with that. He used a stethoscope to try to localise the fault and he checked measuring values with engine running. The sound seems to originate from somewhere under the oil filter. The injector on cylinder no. 2 has has erratic values. Seems like it supplies more than twice as much fuel as the other five. He tried to disconnect an cylinder at a time, as his manual said this would be okay. I know it is not.. Already told him. But, it did not help. He heared the engine slowed down and ran on 5 cylinders. In the clip you can hear the engine. Not a sound I like. He thaught that maybe one of the big end bearing was shot because of the knocking sound. What to do?
    https://youtu.be/JsUsYXrJsOs
  3. Re: Ticking noise, A6 2.7 tdi
    1837 Post(s)
    Can't make it out on the recording but from your description I would say the somehow the balancer shaft has jumped a tooth or two and the weight is hitting a crank counterweight which I think it can do if it is out of time but I have never experimented that far, just got the job done. These engines are getting to the point that even a small issue is the end of the car if it has to be fixed professionally.
    2 2 0
  4. Unhappy Re: Ticking noise, A6 2.7 tdi
    Apr 2015
    Hi Kimlk, I have exactly the same noise as the 1st video you sent and . Did you findout the real cause. I took it to a garage and they don't think it is the chain and said sounds like exhaust / emmission / pressure problem or hole some where. Thanks
    Audi A6 2.7 tdi ticking noise - YouTube
  5. Re: Ticking noise, A6 2.7 tdi
    Oct 2016
    Norway
    Quote Originally Posted by badchi View Post
    Really late reply, but no. I found the usual injector leak that vents trough the designed hole i the head, but not what caused the ticking. Pulled the engine out, lined up everyting, found slight misalignment in camtiming, and refitted engine. Still no joy.. Buy used engine and try again.
  1. 2.5 v6 tdi ticking noise, but where is it coming from???
    By gmac78 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2013, 02:24 PM
  2. Ticking noise on Mk5 GT TDI
    By fridaypassion in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2010, 01:32 PM
  3. Please Help ticking noise bora tdi
    By mark1604m in forum New Member Introductions
    Last Post: 14-12-2009, 03:10 PM
  4. 2.0 tdi no power and a loud ticking noise
    By denlinco in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-04-2009, 10:35 PM
  5. Please Help GT TDI 150 ticking noise?
    By SJamG in forum Golf MK4 - 1999 - 2004
    Last Post: 18-07-2008, 09:56 AM
