Thread: Drivers door lock problem
  1. Drivers door lock problem
    Dec 2016
    U.K.
    Ok so I have the dreaded door lock problem, basically the door won't unlock with fob unless the lock button is pressed twice (deadlock).
    Any reasons as to why this would occur ? I've seen a lot of threads on door lock problems but nobody has mentioned there's will only unlock if unlocking from deadlock.
    Thanks in advance.
  2. Re: Drivers door lock problem
    35 Post(s)
    765 Post(s)
    Quote Originally Posted by Smigga23 View Post
    Yes, mechanical things go wrong.... The first thing to do is get a full code scan done to see what the door control unit and the central convenience unit are seeing as the problem.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  3. Re: Drivers door lock problem
    Dec 2016
    U.K.
    Thanks for that, just seems odd that it will open but only if you press the lock button twice 1st!
  4. Re: Drivers door lock problem
    Oct 2012
    Estonia
    64 Post(s)
    Its door lock-actuator getting weak 90%, before changing it, scan as stated above and try wd40 or spray lock-oil to keyhole and play with fob few times, helped in my case and for few others. If not, replace the lock! It opens second or third time, because more juice in circut as other doors are already open! Same s... was with fuel flap actuator etc...
    Repairing Audi A4 B8 8K door not unlocking with remote fob
    There has been few reports of module issue also, but i put my money to the lock!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  5. Re: Drivers door lock problem
    35 Post(s)
    765 Post(s)
    That is because you are setting up inertia in the internals which allows it to kick the unit open.
  1. Attention Drivers door lock
    By Peter D in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-02-2015, 11:43 PM
  2. Replies: 3
    Last Post: 23-03-2013, 10:15 PM
  3. Please Help Drivers Door Lock/Central Locking Problem
    By Bigdogcasa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2011, 03:38 PM
  4. A6 Drivers door lock problem
    By bobh6742 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-03-2011, 07:14 PM
  5. A6 Drivers Door Lock Sticking and door occasionally not opening
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2010, 10:53 PM
