Thread: Terraclean
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Terraclean
    #11
    Jul 2015
    Staffs
    44 Post(s)
    It's a placebo effect, and unless the MPG is monitored under test conditions you can't really use that as proof. Just my 2p worth.
    Ian
    A4 B6 Avant Nogaro Blue
    0 2 0
  2. Re: Terraclean
    #12
    Oct 2005
    Quote Originally Posted by cjmcb View Post
    I was impressed with my little car being Terraclean'd and it seemed to be more willing to rev afterwards too as well as a hike in mpg from 17 to 20!
    What is your little car?
  3. Re: Terraclean
    #13
    Feb 2015
    bedford & england
    Just wanted to know if it's best to do a full service then a terraclean or before the service as i am looking at getting this done, also is the egr & turbo terraclean separate clean from the standard terraclean?
  4. Re: Terraclean
    #14
    Nov 2010
    Shetland & S.Tyneside
    76 Post(s)
    I'd suggest you change the oil and filter after the cleaning as some of the gunk will possibly end up in the oil. please post with an update on the results of the 'terraclean'
    cheers
    0 2 0
  5. Terraclean
    #15
    Birmingham
    The inlet manifold will not get cleaned as the terraclean is a fuel based cleaner. They swap the fuel lines for there machine and run it on a mixture of their own recipe. This won't come into contact with the inlet as diesels inject straight into the cylinder.
    I had mine done and it did improve the car. But a good motorway drive with diesel additive in does just as good.
  6. Re: Terraclean
    #16
    Nov 2010
    76 Post(s)
    Yes - that's my thoughts on this terraclean and I'm not convinced of it's long term benefits. I've removed the inlet manifold at 120,000 miles on my 1.9 AWX engine and scraped and washed out a good thick layer of carbon crud that was restricting the flow into the intake valve ports, the valve ports themselves were pretty gunked up as well, which need careful cleaning. Doing this gave the engine a new lease of life. The terraclean won't touch any of this, or if it does I hate to think where all the gunk would go !!
  7. Re: Terraclean
    #17
    Nov 2017
    USA
    Quote Originally Posted by JettaJames View Post
    Hello,
    I decided to get my Jetta 2.0t tfsi engine terracleaned. I had BOTH the normal terraclean and the turbo clean. Wow!
    Engine is quieter, smoother and the mpg has been improved.
    Mine is an 08 plate but with sizegenetics review on aboutmens just 25k on the clock: it had done lots of short journeys and clearly had lots of carbon deposits inside.
    I will update with how this continues but initial impressions are very good indeed!
    Thanks for the heads up JettaJames. good work I'll give this terraclean stuff a try.
  8. Re: Terraclean
    #18
    Dec 2016
    Nottingham
    You’re welcome!
  9. Re: Terraclean
    #19
    Apr 2018
    Wood Dale, USA
    Hello,
    Engine is quieter, smoother and the mpg the crazy bulk has been improved too.
    Mine is an 08 plate but with just 25k on the clock: it had done lots of short journeys and clearly had lots of carbon deposits inside.
    A nice combo. Got to see how it goes in the long run.
  10. Re: Terraclean
    #20
    Feb 2015
    bedford & england
    Nice
    How much did both cost to get done?
  1. Terraclean anyone?
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-04-2016, 12:52 PM
  2. Terraclean Review
    By s114hed in forum Chat - Anything with wheels
    Last Post: 29-03-2015, 09:51 PM
  3. Terraclean!!!!
    By poosnip in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-02-2015, 02:21 PM
  4. Question Terraclean De-carbonizing
    By thechippy03 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2013, 02:47 AM
  5. Question Terraclean - anyone had it done?
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2013, 10:55 PM
