Thread: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
Results 1 to 10 of 10
  1. Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Jul 2011
    St Neots
    18 Post(s)
    I went to fill up last week and couldn't get the diesel nozzle in.
    Stopped myself a minute to double check the car/fuel combo was right, or that i hadn't gone mental somehow.
    I found this little metal plate has appeared over the top of the fuel filler pipe, just behind there the cap sits. A rough wiggle and it pivoted away and i filled up.
    Its now back and stuck pretty firm. I can only slowly trickle fuel around the sides. For some reason attachment manager is rotating my photo.
    What a mental defect, a car which of its own choosing stops me putting fuel in it!
    I assume this is perhaps an anti-siphon plate normally moved away by the central locking which has in my case failed?
    Any ideas? A quick fix?
    rob
    S6 Black Avant: Tech advanced, Matrix, Keyless entry, Sunroof, Speed limit display, Tow bar, Rear camera
    Golf GTI (for the Mrs) BMW M140i (for work and fun )
  2. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Nov 2016
    Preston
    9 Post(s)
    Is it not the misfueling device?
    Awaiting A6 Avant Quattro SE Executive 3.0 TDI 218ps.
    Metallic Diamond beige, adaptive air suspension, Bose surround sound, LED matrix headlights, parking pack, technology pack, ambient lighting, heated folding mirrors, comfort seats, privacy glass and finally a swivelling ball!
  3. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Mar 2014
    Edinburgh
    235 Post(s)
    Is that not the anti syphoning device. Meant to stop people chucking a hose down the Filler and stealing your diesel.
  4. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Jul 2011
    St Neots
    18 Post(s)
    I think so but how do get rid of it/make it work properly...
  5. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Mar 2014
    Edinburgh
    235 Post(s)
    If it's under warranty send it to the dealers.
    If it's not I would be tempted to ram a screw driver in there. If it drops in the fuel tank it's too big to get sucked in the fuel system.
    Another option is to call a recovery (aa, rac) next time you fill up and see if they have a fix.
  6. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Nov 2012
    Somerset UK
    Not an uncommon occurrence apparently according to google
    How-To Remove/Install the Misfuel Adapter 2013 Jetta - TDIClub Forums
    Before you experienced this did anyone else put fuel in the car?
  7. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    1837 Post(s)
    The pins are£6.02 each
    2 0 0
  8. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Jul 2011
    St Neots
    18 Post(s)
    Interesting, thanks!
    Reading this maybe it was just a really work or mis shaped fuel nozzle. It was a garage i don't often use and it looked pretty bashed.
    I think i will try filling up again somewhere else and maybe there wont be a problem.
  9. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Dec 2016
    Edinburgh, Scotland
    15 Post(s)
    Hope you get it sorted!
    Mine did a similar thing but the "clicky" fuel flap locking clicker failed in the locked position.....back to Audi before I ran out of fuel. They said i was part of a bad batch of clickers and it had been a common fault.
  10. Re: Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    Jul 2011
    St Neots
    18 Post(s)
    Yep, fuel up today. New BP garage. No issues, metal plate disappeared as soon as the nozzle touch it, just like normal i guess. Must have simply been a worn out nozzle. PHEW!
    Thanks for the advice all!
  1. Loose/Rattling Metal Plate under the boot
    By alasdaircm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-05-2016, 01:02 PM
  2. Please Help Metal in fuel system £3000 bill
    By Felonator in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-10-2015, 05:58 PM
  3. Question Metal fillings in MK5 fuel filter
    By polo2002 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-08-2011, 10:23 AM
  4. Attention Split metal fuel line, 1.8T
    By Redbrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2009, 03:53 PM
  5. Question AFS (adaptive frontlight system) defect after battery defect
    By aluco123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-12-2008, 05:28 AM
