Thread: MIL lamp on and warning beep Touareg 2.5 diesel 2003
Results 1 to 10 of 18
  1. MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi all
    My niece has a Touareg with the 2.5 4 cylinder diesel engine 2003 year
    Runs and drives great but recently it is putting the MIL lamp on and gives the warning beep
    I have read the fault code P0571 (with Snap On Ethos my vagcom lead has stopped working)
    Code read is P0571 - Brake switch implausible signal - intermittent
    I have replaced the brake light switch, but within in a few hours the fault returned
    Any help is appreciated
  2. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Pembrokeshire
    22 Post(s)
    i am presuming you have checked the brake lights are working.... i had a passat, same or similar code and no lights. replaced the switch, exactly the same. old switch back in, 2 new bulbs, job done. code cleared never to return.
  3. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    1837 Post(s)
    Where did the switch come from and did you install it pedal up or pedal down?
  4. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    To give a little more information, this is my nieces car and she live's near Southend on Sea (I live in Nuneaton) so all of this is been done long distance
    I am not sure what make of switch or the position of the switch (I have asked but not had an answer as yet), she took the car to a local garage and had them fit the switch and clear the fault code, they also fitted a set of glow plugs.
    The car is still running ok but recently the MIL lamp is on and gives the warning beep fault code P0571 still present and the Green Auto box symbol please see photo is light and some times it will not move from Park to Drive?
    Summary MIL/Glowplug light on, Green auto box light on and the car will not change from Park to Drive (the only way to get it to move from Park to Drive is to stop and restart the engine this can take several goes
    Is there anyone local to where my niece lives with Vagcom?
    Thanks for all the help
  5. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    1837 Post(s)
    With code
    16955 (P0571) - Brake Light Switch (F): Implausible Signal
    after a new switch has been fitted my assumption would be that the switch has been incorrectly fitted, there are two ways depending on the part number of the switch.
  6. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    With code
    OK thank I will get my niece to check with the garage
  7. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi we think the switch came from Eurocarparts
    How many switches are there on the brake pedal?
  8. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    1837 Post(s)
    PM me the reg
  9. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi Crasher
    PM sent thanks
  10. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    1837 Post(s)
    The genuine VW number for the switch is 7L6 945 511 and these cost £13.60, ECP offer this in four different numbers of three distinctly different design variations by two different manufactures, we need to know which one they fitted,
  1. Please Help MIL lamp on 'Emission' warning and loads of black smoke
    By mumutley in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-07-2016, 12:04 AM
  2. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  3. Please Help 2002 Audi A4 1.8 MIL lamp on with cooling fans at startup
    By Richard the 3rd in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2010, 02:27 AM
  4. Replacing MIL lamp
    By ireisberg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2009, 04:14 PM
  5. Question Mil lamp
    By greros1 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-05-2009, 06:47 PM
