Thread: MIL lamp on and warning beep Touareg 2.5 diesel 2003
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi Crasher
    I will try and find out the part number supplied and fitted
    Thanks for your help and assistance
  2. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    I have passed details 'The genuine VW number for the switch is 7L6 945 511' on to my niece she's going to order one from a local VW garage where she lives.
    What will the correct fitment procedure be?
  3. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    1840 Post(s)
    The correct procedure for this version of switch is pedal up in the rest position.
  4. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi Crasher - Happy New Year to you and all
    With the pedal in the up position, should the protruding rod on the switch be pulled all the way out before fitting?
    So as the switch is fitted in to position the rod is pushed back in?
  5. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Dec 2014
    Bedford
    42 Post(s)
    Definitely don't pull out the rod. Fit like Crasher said pedal up in rest position turn to the right until you hear a small click this activates the switch in the correct position and thus allows continuity through the switch. You only get one chance at fitting this switch correctly so absolutely don't mess with the rod.
    Sent from my SM-G900F using Tapatalk
    2 1 0
  6. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    Jan 2009
    Nuneaton England
    6 Post(s)
  7. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    #17
    1840 Post(s)
    Yep, don't fiddle with it, just twist to fit. Even then having done hundreds and only using genuine I still get the odd one that fails instantly.
  8. Re: MIL lamp on and warning beep Touareg 2.5 diesel 2003
    #18
    Jan 2009
    Nuneaton England
    6 Post(s)
    Brilliant thanks all
    My niece as got the switch from VW and is coming up to see me next weekend, so I guess that's her way of asking me to fit it
  1. Please Help MIL lamp on 'Emission' warning and loads of black smoke
    By mumutley in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-07-2016, 12:04 AM
  2. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  3. Please Help 2002 Audi A4 1.8 MIL lamp on with cooling fans at startup
    By Richard the 3rd in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2010, 02:27 AM
  4. Replacing MIL lamp
    By ireisberg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2009, 04:14 PM
  5. Question Mil lamp
    By greros1 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-05-2009, 06:47 PM
