Thread: Fabia SDi - Problems
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Re: Fabia SDi - Problems
    #21
    Feb 2009
    Preston
    Ok, Will have to take it to the garage for this, I don't have the tools to do a proper test on it.
    I guess, this is pointing to piston rings or bent valves? I'm going more piston rings due to I have noticed I'm losing some oil now!
  2. Re: Fabia SDi - Problems
    #22
    1836 Post(s)
    It could be a compression ring problem but it certainly not a common problem, my guess is the cam belt was timing screwed up and it has bent a valve. Any decent garage should have a diesel compression tester and the M10x1 adapter for the glow plug hole. Once removed, I don't recommend reusing glow plugs, they can easily snap and ruin your day.
  3. Re: Fabia SDi - Problems
    #23
    Feb 2009
    Preston
    Ok, this makes sense especially as the timing was out it could have caused a fair bit of damage.
    In you opinion would it be worth fixing it all, jibbing a new (used) engine in or just cutting my losses and moving on with the cost of labour etc.
  4. Re: Fabia SDi - Problems
    #24
    1836 Post(s)
    Finding a good used engine will be difficult, get a compression test done first.
  1. Please Help Fabia immobiliser problems
    By kateb in forum Fabia
    Last Post: 11-08-2015, 08:54 AM
  2. Please Help Fabia 1.9 SDI - running rough, no power, is it the ecu?
    By GRAHAM COGSWELL in forum Fabia
    Last Post: 05-01-2013, 07:52 PM
  3. 2005 mk 5 sdi problems
    By mbev51 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-10-2009, 02:01 PM
  4. Question How reliable is a 2000-2001 Fabia 1.9 SDI
    By harry100 in forum Fabia
    Last Post: 21-07-2009, 06:07 PM
  5. Fabia 1.9 SDi Starter Motor
    By deputy899 in forum Fabia
    Last Post: 04-12-2007, 11:37 AM
