Thread: No hot air, most of the time. All vents, controls working, in and out hot.
Results 1 to 10 of 16
  1. No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2016
    Bath, UK
    Search brought up a few options but wanted to check.
    Audi A4 Avant from 2003.
    All climate control / air con controls are working.
    All vents pumping out air.
    The only problem is...sometimes it's warm, most times it's not.
    I've read it could be matrix or motor but as it is sometimes going hot wondered...
    So it works and it doesn't work. More not then does.
    Any suggestions?
    In and out pipes both warm, low to high controls all blow at different levels, all vents blow as they should.
    System has been checked and small bit of air flushed out.
    Fuses checked.
    No wet foot wells.
    Thanks.
  2. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Sep 2008
    chester
    17 Post(s)
    Does it get up to 90 degrees on the temp gauge?
  3. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2016
    Bath, UK
    Hi, it does yes. And no wet foot wells.
  4. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Sep 2008
    chester
    17 Post(s)
    Does that include watching all the levers/servo's operating.
  5. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2016
    Bath, UK
    Not sure there. I assume levers / servos would be internal things...in which case no.
    Choosing particular buttons on control panel certainly makes a difference to direction etc, amount of air, etc.
  6. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Sep 2008
    chester
    17 Post(s)
    Because its getting warm some of the time suggest its not the matrix like you've said ,is the engine temp take its normal time to reach 90.
  7. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2016
    Bath, UK
    I've only had car a couple of weeks so not sure what is normal for this one but it gets to 90 no slower than other cars I've owned.
  8. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2009
    southampton uk
    I would still change the stat.The matrix pipes must get hot for it to function
  9. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2016
    Bath, UK
    Thanks Mike. Gets to 90 and stays constant so I guess that points to stat being ok.
    I'd love to be able to at least try a fix myself at first but may call the local(ish) audi specialist today...
  10. Re: No hot air, most of the time. All vents, controls working, in and out hot.
    Dec 2009
    southampton uk
    If you are sure the stats OK and still no hot pipe to matrix maybe it needs flushing and bleeding.The matrix may have some gunge in it if proper coolant hasnt always been used.Not easy to clean them but worth a go rather than trying a swop
  1. Air vents clicking / popping on hot weather
    By dragos29 in forum Q7 - 4M Forum - 2016 -
    Last Post: 27-08-2016, 07:42 PM
  2. Question Climate Control Blows Very Hot Air Then Returns to Normal after Time
    By sanstorm999 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-10-2012, 04:32 PM
  3. Please Help No hot air from blower and engine temperature gauge not working right
    By stevebora in forum Golf MK3 - 1993 - 1999
    Last Post: 19-07-2011, 11:36 PM
  4. Air vents blow only Hot Air
    By nash232 in forum Ibiza - Cordoba
    Last Post: 22-04-2009, 08:44 PM
  5. Hot & Cold Air from Vents
    By HChaloner in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-11-2007, 03:29 PM
