Thread: GOLF TDI 1.9 Sport- 06 Plate | weird noises
Results 1 to 10 of 13
  1. GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Dec 2016
    England
    So firstly I have just bought this vehicle and it is my first Diesel so I am not sure what sounds are normal and what are not.
    I am worries about two things that I can't explain.
    1- When I turn my car off there is a deflating/whining sound for 1-2 seconds and it looks to me as if it goes hand in hand with the speed/Rev dials, when dials are going down. when they hit 0 the sound stops.
    2- When car is idling, the car makes a mild noise every now and then something between Griding/rattles or Russtling noise.
    please let me know if anything is wrong or if everything is fine.
    Video of Delating/Whining sound - https://vid.me/jN9d
  2. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That deflating sound could be due to your anti shudder / throttle intake flap not closing when ignition is turned off. also check for loose or flapping auxilliary drive belt due to tensioner failure or alternator pulley sprag clutch sticking, rattles or grinding noises could be dual mass flywheel fault - does the rattle noise change if you press in the clutch or have the car in gear and ride the clutch slightly.
  3. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Dec 2016
    England
    Thanks,
    I haven't tested it with the clutch, once I have done so I will get back to you.
    But its not very loud hard to tell until listening carefully from inside of car, you can feel mild jolts in the car when it does that somewhat rattling sound.
    almost like something spinning but not properly sometimes.
    From what you have mentioned is this an easy job to fix or will it cost a lot?
  4. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Nov 2010
    104 Post(s)
    If it is the flywheel that's failed I'd budget for several hundred pounds, presuming you aren't looking to do this yourself. It may be the reason why the car was up for sale. On the other hand it could be something simple. If you got it from a garage I'd get confirmation of the fault from a mechanic and take it back to the garage.
  5. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Dec 2016
    England
    ok thanks, and what about the flap and the deflating sound is that a major one too
  6. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    1844 Post(s)
    Turn the AC to ECON before shutting down and see what happens.
  7. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Dec 2016
    England
    @Rob
    I checked service history and the Flywheel well (clutch kit x2) was changed about 11months ago.
    @Crasher
    Thanks I will test that when turning ignition off
  8. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Dec 2016
    England
    Ok so I have some what tested this now.
    With ECON on, the noise is still there when turning off.
    The rattling/grinding seems to go away when clutch is pressed.
  9. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    1844 Post(s)
    Box back out and investigate what went wrong, probably a SMF conversion or did not fit a new DMF.
  10. Re: GOLF TDI 1.9 Sport- 06 Plate | weird noises
    Dec 2016
    England
    @Crasher
    I don't get what you mean?
    Are you saying it used to be a DMF and was switched to a SMF which makes noise? or?
  1. Now it's making weird noises
    By TDiBoraSam in forum Golf MK6 - 2009 - 2013
    Last Post: 22-11-2015, 09:47 PM
  2. Weird noises from front of car
    By Alfonzo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-09-2013, 12:25 PM
  3. using biodiesel in tdi sport, 55 plate b6
    By ianth in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-09-2009, 09:50 AM
  4. help.. advice.. golf gt tdi 150pd strange noises..
    By jambo005 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-04-2009, 09:27 PM
  5. 2005 Golf Tdi Se Dsg - Strange Noises When Idling
    By shairaz1 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-01-2009, 06:30 PM
