Thread: Handbrake adjustment
  1. Handbrake adjustment
    Nov 2013
    west midlands
    Hi there any advice about hand break adjustment Haynes says to take off centre console and press down on the click to release
    I can't seem to do it no matter what any tips it's a b6 2001
  2. Re: Handbrake adjustment
    Jan 2009
    Birmingham
    36 Post(s)
    its self adjusting have you changed the cable or something
  3. Re: Handbrake adjustment
    Jan 2009
    Birmingham
    36 Post(s)
    anyways is this any help
    Adjusting handbrake
    Note
    t The rear brakes are self-adjusting, so the handbrake does not require [COLOR=#1B8EDE !important]adjustment[/COLOR] in normal[COLOR=#1B8EDE !important]operation[/COLOR]. Re-adjustment is only necessary after renewing handbrake cables, brake calipers, brake pads or brake discs.
    t The footbrake system must be bled and must be functioning properly.
    t Handbrake lever, handbrake cables and brackets must be fully installed.
    [COLOR=#1B8EDE !important]Adjust[/COLOR] lever position at brake calipers using feeler gauges to ensure that A = 1.5 mm.
    Depress brake pedal firmly at least three times.
    For [COLOR=#1B8EDE !important]illustration[/COLOR] purposes, the [COLOR=#1B8EDE !important]diagram[/COLOR] shows the handbrake lever after it has been removed from the vehicle.
    Press release button, item -2-. (Both spring-loaded hooks must catch eyelets on handbrake cable.)
    Let go of the release button.
    Firmly apply the handbrake lever at least 3 times.
    Place handbrake lever in rest position.
    Press release button. (Both spring-loaded hooks must catch eyelets on handbrake cable).
    [COLOR=#1B8EDE !important]Remove[/COLOR] feeler gauge from brake calipers.
    Check lever position at brake calipers.
    Distance A between lever and stop must be between 0 and 1.5 mm.
  4. Re: Handbrake adjustment
    Nov 2013
    west midlands
    Thanks that's the intructions I have been following it says about pressing the release button on the circle metal part under the centre console. It doesn't seem to do anything
    I haven't had any work done but the handbrakes not great it has to be yanked up to work ok.
    When I looked underneath one of the callipers was no where near the stop so not fully on
  5. Re: Handbrake adjustment
    Jan 2009
    Birmingham
    36 Post(s)
    IMG_4656.jpgHave a look at you rear calipers there should be spring on each one give them a good spray with wd40 and then try handbrake
    By ytre in forum Jetta MK3 - 2005 - 2013
    Last Post: 08-08-2011, 07:27 AM
  2. How To Handbrake adjustment
    By ytre in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2010, 05:09 PM
  3. Handbrake Adjustment
    By Llew86 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2010, 02:12 PM
  4. How To Handbrake adjustment
    By Andante in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2009, 12:25 AM
  5. Handbrake Adjustment
    By grahamcoutts in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-10-2008, 07:51 AM
