Thread: CVT Gear box oil change
Results 1 to 8 of 8
  1. CVT Gear box oil change
    Mar 2010
    Galway, Ireland
    Is it possible to buy the special tool needed for changing the gearbox oil in my Audi A4 cvt box?
    As I understand it, the thread on the VW tool is different and therefore wont work
    Thanks in advance!
    '09 A4 SE 143hp Multitronic - Quartz Grey
  2. Re: CVT Gear box oil change
    Oct 2012
    Estonia
    64 Post(s)
    Check audizine, ive posted there few times alternative, where you fill oil from "outer filter". But you probably can buy oem tool(VAS5162) for that, something like this(probably aftermarket unit on picture-not sure):
    http://www.autoinstrument.su/media/u...c8f2528539.png
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
    1 1 0
  3. Re: CVT Gear box oil change
    Feb 2016
    australia
    The transmission fluid is filled from the drain hole.
    The dealers use on of these.
    I made my own with a adapter i bought on Ebay, clear hose and a bottle. which worked fine.
    the fluid is gravity fed like this.
    when you unscrew the drain plug you need to remove the breather pipe otherwise all the fluid won't drain out.
    when you have filled the transmission with about 7-8 liters you need to run the car and cycle through the gears, monitor the transmission fluid temp with a VAG device. When the fluid reaches between 35-40 degrees you allow the excess fluid to spill out then replace the plug and your done.
    this is difficult to do without a hoist.
    2 2 0
  4. Re: CVT Gear box oil change
    Mar 2010
    Galway, Ireland
    Thanks Gunnark100!
  5. Re: CVT Gear box oil change
    Mar 2010
    Galway, Ireland
    Thanks Steve26... Appreciate all the detail given... did you buy the adaptor or did you make it using an inspection plug?
    Also found this website www.mectronic.fi while searching for information to help with this issue... some great details on it!
  6. Re: CVT Gear box oil change
    Feb 2016
    australia
  7. Re: CVT Gear box oil change
    Mar 2010
    Galway, Ireland
    Thanks for the link
  8. Re: CVT Gear box oil change
    Sep 2014
    COLOMBO, SRILANKA
    Quote Originally Posted by Gunnark100 View Post
    Hi, searched Audizine A4 B8 forum for your comment on CVT oil cHange but failed.
    Would you care to tell us how you refill CVT box through the filter ? I'm going to do that and will appreciate your easy method.
  1. Gear Box Oil Change (2007 CVT 2.7 Tdi v6)
    By pavsingh in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-04-2013, 05:29 PM
  2. Please Help Automatic gear box oil change?
    By stokie1970 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2012, 12:12 PM
  3. Please Help auto gear box oil change
    By ssargent in forum 80 - 90
    Last Post: 29-09-2009, 11:51 AM
  4. Gear box oil change ?
    By natz in forum Golf MK4 - 1999 - 2004
    Last Post: 12-06-2008, 03:04 PM
  5. CVT gear box
    By A6_JAck in forum Archive posts
    Last Post: 30-08-2007, 11:23 PM
