Thread: '06 Fabia wheel alignment - front camber issue?
  1. Question '06 Fabia wheel alignment - front camber issue?
    Sep 2008
    Merseyside
    since getting my son's 06 1.2 fabia it has pulled to the left by a quite noticeable amount. the tyre wear is fine, and finally I got around to getting the tracking looked at. it showed that the front toe-in was out, and got corrected, but it also shows front camber to be out on both sides.
    Has anybody faced similar issues? doing a quick search on the forum, other VAG cars have camber issues, and the camber is not adjustable on many of the models. is this the case, or has anybody had similar and found that replacing things like ARB and other such suspension links/bushes etc helped?
    any thoughts, guidance and similar appreciated.
    Cheers,
    Pete
  2. Re: '06 Fabia wheel alignment - front camber issue?
    Pembrokeshire
    22 Post(s)
    are the lower ball joint not adjustable on it . 3 bolts, loosen and allows you to slide in or out to alter camber ?
  3. Re: '06 Fabia wheel alignment - front camber issue?
    Sep 2008
    Merseyside
    Hi Zolaff - not sure, haven't been under it for a few weeks, but will have another look at the haynes manual tonight to see if there is anything that looks obvious (and then take a look at the car when my son is back at the weekend).
    thanks,
    Pete
  4. Re: '06 Fabia wheel alignment - front camber issue?
    Jul 2015
    Staffs
    46 Post(s)
    I don't believe they are camber adjustable. If its excessive, or causing outer edge wear its more than likely the rear lower control arm bushes that are worn.
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: '06 Fabia wheel alignment - front camber issue?
    Sep 2008
    Merseyside
    did a quick web search and came across the skoda specific forum with a step by step guide, here - Fabia wishbone bush replacement DIY Guide - Skoda Fabia Technical Guides - BRISKODA
    Guess my weekend will involve me getting my lads fabia up on ramps and seeing what state the various bushes are in, but at 110k miles on crappy british roads, there is a fair chance that they will be in need of repacement.
    thanks for the replies so far, much appreciated.
    Pete
  6. Re: '06 Fabia wheel alignment - front camber issue?
    Jul 2015
    Staffs
    46 Post(s)
    My wife's Fabia's were changed at 90k.
    They're in the rear subframe, so unless you change them in situ, you need to make sure its put it back it and aligned properly. It will give alignment issue if you don't.
    Ian
  1. front wheel alignment data
    By kblackburn in forum Exeo
    Last Post: 30-12-2012, 09:49 PM
  2. 4 Wheel alignment/ rear camber adjustment
    By xenon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-08-2012, 04:09 PM
  3. Passat Front Wheel Positive Camber
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2012, 02:59 PM
  4. A6 Quattro front wheel alignment
    By martink in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2009, 10:51 PM
  5. Camber alignment - is it a big issue
    By blairmiller166@ in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-06-2007, 12:11 PM
free web
stats
