Thread: 1.6 BSE A3 Power Loss - Exhaust/Cat Problem???
  1. 1.6 BSE A3 Power Loss - Exhaust/Cat Problem???
    Apr 2016
    N.Ireland
    Hi. We have a 2010 1.6 petrol a3 with BSE engine.
    Currently its giving a p0304 cylinder 4 misfire code. We now believe after a lot of messing that it is an exhaust or cat restriction causing the problem or another mechanic suggested possibly an o2 sensor failed.
    I have recently bought OBDeleven Pro so i think i could measure live data to test where the problem may be first before pulling the car apart again. But unsure how to use it properly.
    Its recently had an engine change as previous one we were told had cracked cylinder rings on piston 4. Now this one is starting to act the same but not as bad yet. Left untreated i think it will end up the same as the old engine.
    Im guessing an exhaust/cat restriction caused extra strain on cylinder 4 which over time broke the piston rings on the original engine. (75k miles on it)
    Parts replaced so far is
    Engine
    Injectors
    New Plugs
    New Leads
    New coil pack
    Only thing not changed yet is exhaust/cat
    Any help or advice here on what i should do to sort it out.
  2. Re: 1.6 BSE A3 Power Loss - Exhaust/Cat Problem???
    108 Post(s)
    1816 Post(s)
    The BSE is an 8v engine and they are prone to valve guide wear which causes a burnt out exhaust valve so before you do anything else, get an accurate compression test done.
  1. Question 1.8t Aum power loss problem
    By MikeCrum1996 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-01-2018, 03:36 PM
  2. passat s tdi 130 auto - engine power loss, exhaust smoke
    By hoffmeister in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-08-2009, 07:30 PM
  3. same old power loss problem...
    By legrandefromage in forum New Member Introductions
    Last Post: 02-07-2009, 02:33 PM
  4. Exhaust Warning Light / Loss of Power
    By hattoncote in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-06-2009, 06:09 PM
  5. Please Help Abrupt loss of power and loooaads of white smoke out of the exhaust
    By s-line(amg88) in forum Audi A3 - Archive Topics
    Last Post: 17-12-2008, 06:20 AM
