Thread: 2005 TDI 130 juddering under load
Results 1 to 10 of 19
  1. 2005 TDI 130 juddering under load
    Nov 2016
    galway ireland
    Hey
    My 2005 TDI 130 started developing a juddering/shaking under load over the last couple of months. Usually occurs from ~1500 - 2000 rpm and is not consistent - sometimes there is little to no vibration.
    Always been serviced on time and with correct oil etc.
    Plugged in and no fault codes showed up.
    Injector wiring loom replaced and problem remains.
    Recently engine management light and Emissions Workshop warning message have appeared intermittently along with a loss of power.
    Any ideas what the cause is ?
    Cheers !
  2. Re: 2005 TDI 130 juddering under load
    Pembrokeshire
    22 Post(s)
    what you scanned it with ??
  3. Re: 2005 TDI 130 juddering under load
    Nov 2016
    galway ireland
    Launch
  4. Re: 2005 TDI 130 juddering under load
    Pembrokeshire
    22 Post(s)
    cool, so that should find any codes. some people scan with a 1.99 ebay jobbie and wonder why they cant find any codes.. you say juddering and shaking under load, is there always loss of power. could the juddring be dmf or engine mounts.
  5. Re: 2005 TDI 130 juddering under load
    Nov 2016
    galway ireland
    There isnt always a loss of power, it happens approx 50% of the time and when it does it lags up to ~2000 rpm then power returns as normal. Spoke to two different mechanics who ruled out both dmf and loose engine mounts.
    At the moment I'm leaning towards it being an injector issue ? Other possibilities are the maf and fuel filter.
  6. Re: 2005 TDI 130 juddering under load
    May 2012
    Everywhere
    308 Post(s)
    Injector loom .
  7. Re: 2005 TDI 130 juddering under load
    Pembrokeshire
    22 Post(s)
    Quote Originally Posted by Gazwould View Post
    Injector loom .
    myfirstthoughtbutthatsbeenreplaced
  8. Re: 2005 TDI 130 juddering under load
    Pembrokeshire
    22 Post(s)
    oh look at that, cannnot put a space in, stoopid computers.
  9. Re: 2005 TDI 130 juddering under load
    May 2012
    Everywhere
    308 Post(s)
    I should of gonetospecsavers .
    1 1 0
  10. Re: 2005 TDI 130 juddering under load
    Jul 2015
    Staffs
    46 Post(s)
    I would swap out the MAF for a used unit and see what happens.
    Ian
    A4 B6 Avant Nogaro Blue
  1. 2002 Tdi 130 Juddering / Misfire
    By groovyg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-01-2011, 05:04 PM
  2. Attention TDI 130 juddering on acceleration
    By Martini B in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2011, 12:20 PM
  3. 2002 a4 tdi 130 se juddering please help.
    By gaz7216 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2010, 11:05 PM
  4. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  5. a3 tdi 130 juddering
    By bokbok in forum Audi A3 - Archive Topics
    Last Post: 21-11-2008, 01:32 AM
