Thread: Rear Wiper
  1. Rear Wiper
    Nov 2016
    Derby
    Hi I'm new here and I'm hoping someone can help.
    I have an Avant which the last couple of trips the rear wiper does what it likes! It started with it starting intermittently for no reason but this morning i washed the window and the wiper stayed on until i stopped. It stopped for a while then started intermittently working again without the stalk being on. There are no faults when read or stored.
    Was wondering if it was a faulty rely or something.
    Has anyone else had or know of this issue?
    Scott
  2. Re: Rear Wiper
    43 Post(s)
    In the cases of other models it usually means the motor will shortly cease to work very shortly.
  3. Re: Rear Wiper
    Cork
    Usually the water hose is leaking or has come off. Shorting connections on the controller or motor.
    Sent from my Brain via my Keyboard
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  4. Re: Rear Wiper
    Nov 2016
    Derby
    Thanks. Only one jet is working out of the two which I've had before which was just a blockage. I take it it's a new motor then.
  5. Re: Rear Wiper
    Aug 2014
    Slovenia
    You will have to remove plastic cover and inspect motor and its circuit. My case was different but this is how it looked. So much about truth in engineering...
    AUDI A4 B8 2.0TDI 2010 100kW CAGB
  6. Re: Rear Wiper
    Nov 2016
    Derby
    On the way home it was on all the time, opened the boot when I got home and water spilled out of the plastic trim. Stripped it down and yes it was leaking in the unit. I've stripped it down and looking at at a repair or replacement.
    Thanks for the advice.
  1. Replies: 3
    Last Post: 09-01-2013, 01:14 AM
  2. Rear wiper
    By mauricedar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-03-2010, 10:40 PM
  3. Please Help 1995 POLO 1.3CL heated rear window and rear wiper, heated door miirrors problems
    By Ray P in forum Polo - Derby - Lupo - Fox
    Last Post: 14-12-2009, 10:15 AM
  4. Please Help 1995 POLO 1.3CL heated rear window and rear wiper, heated door miirrors problems
    Last Post: 14-12-2009, 12:01 AM
  5. '97 A3 rear tailgate and rear wiper
    By steveoh in forum Audi A3 - Archive Topics
    Last Post: 07-03-2008, 11:25 PM
