Thread: VCDS not communicating with my Mk V Golf
  1. VCDS not communicating with my Mk V Golf
    Nov 2016
    Ireland
    14 Post(s)
    I tried to connect our genuine version of VCDS to the mk v golf today in order to try and change the odometer to from Km to Miles as suggested above but VCDS doesn't seem to want to connect to the Mk V for some reason. This is the 1st time I've tried to use VCDS on this car.
    Its the latest version 16.8. I tried VCDS on my old Golf Mk iv and it worked on that car ok as usual. I just select the model from the chasis number and it auto scanned as it always did.
    When I try Auto-Scan on the Mk V golf it says to select Auto-Detect for Can bus which I selected as the MK V is Can Bus. I get the following error "Scan Auto Detect. Function not supported by the gateway".
    I also then tried to select a Mk V golf from the chassis list "Chassis Type 1K - VW Golf/Jetta V (2004 - 2009) Scan: Auto detect
    When I plug the cable in to the Mk V golf the light on the cable goes from red to solid green as normal and everything looks ok.
    Does anyone have any ideas why it won't communicate with the Mk V or am I doing something wrong?
  2. Re: VCDS not communicating with my Mk V Golf??
    Nov 2016
    Ireland
    14 Post(s)
    Anyone got any ideas on how I can get VCDS to talk to the Mk V?
  3. Re: VCDS not communicating with my Mk V Golf??
    1837 Post(s)
    What is the interface you are using?
  4. Re: VCDS not communicating with my Mk V Golf??
    Nov 2016
    Ireland
    14 Post(s)
    Hi, not sure what you mean by "Interface"? I'm using a genuine up to date version of VCDS on a laptop with the genuine supplied cable.
  5. Re: VCDS not communicating with my Mk V Golf
    Oct 2005
    Which cable are you using?
  6. Re: VCDS not communicating with my Mk V Golf??
    1837 Post(s)
    Quote Originally Posted by TdiBlacky140 View Post
    Interface is just another name for the cable. Go into the options menu, do the USB test and post the result.
  7. Re: VCDS not communicating with my Mk V Golf??
    Nov 2016
    Ireland
    14 Post(s)
    Wrote on the cable is:
    HEX + CAN
    Dual-K & CAN <>USB
    Interface for VCDS
    Here's a pic of the results, this is the same message I usually see when testing it on the Mk IV golf and everything works ok on that car.
  8. Re: VCDS not communicating with my Mk V Golf
    Oct 2005
    The Brain will probably have the answer but just to humour me, what happens if you do [SELECT] [19-CAN Gateway]?
  9. Re: VCDS not communicating with my Mk V Golf
    1837 Post(s)
    Quote Originally Posted by Sam View Post
    Not been called that for a while, since The Golf + mag folded, never did quite feel comfortable with the moniker...
  1. VCDS-lite seems to be communicating but nothing read
    By ellaguru2u in forum VCDS - General Questions
    Last Post: 19-10-2015, 02:41 PM
  2. Mk 5 golf gttdi vcds faults
    By Daza23 in forum VCDS - Help Requests
    Last Post: 17-06-2015, 04:41 PM
  3. ABS not communicating with steering wheel
    By C39KER in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 02-01-2015, 02:18 PM
  4. ABS not communicating with dashboard
    By solo284 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-06-2011, 07:48 PM
  5. EOBD Plug Not communicating!?
    By Dacabbie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 07:56 PM
