Thread: A3 2.0 TDI Quattro DPF issues
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
  1. A3 2.0 TDI Quattro DPF issues
    Mar 2015
    Fleet, Hampshire, United Kingdom
    Hi All, I am hoping one of your friendly people can shed some light on an ongoing issue with my A3..
    The DPF light comes on and goes into LIMP mode on within 50 miles of travel under normal daytime load.
    Parts swapped so far:
    DPF Sensor
    Pressure Sensor
    EGR Valve
    DPF.
    It has been to 3 Audi specialists and a Main dealer...
    The car runs fine, then DPF light comes on... I then plugged in VCDS to check and the DPF reads about 36% on the coefficient scale.
    within 10 miles the car goes into limp mode.
    I enter the 21295 regen code and keep it above 40mph at around 2500 rpms after a 15 mile journey the % reads 15, the lights go out and engine returns to normal running mode...
    however the % increases rapidly so its a matter of say 15 more miles before the dpf light is back on.
    The injectors have been removed sent off for test and refurbed and came back within tolerance.
    the idle is smooth and im not picking up on a misfire ....
    I now have seemed to run of options ....
    Any ideas or a plan of action would be gratefully received.
    Cheers in advance
    Neil
  2. Re: A3 2.0 TDI Quattro DPF issues
    Dec 2014
    Bedford
    42 Post(s)
    What's the dpf offset value in measured value blocks? Also what are the temperature readings from cold of the 3 or 4 exhaust gas temperature sensors in measured values?
    Sent from my SM-G900F using Tapatalk
  3. Re: A3 2.0 TDI Quattro DPF issues
    1840 Post(s)
    Year and engine type code? Is it remapped?
  4. Re: A3 2.0 TDI Quattro DPF issues
    Mar 2015
    Hi The Mbar offset was 0
    I have just been for a regen drive and logged what I thought was possible relevant...
    Log-WAUZZZ8P77A059552-168810km-104893mi.txt
  5. Re: A3 2.0 TDI Quattro DPF issues
    1840 Post(s)
    Are you sure that none of the injectors are the potentially problematic part number?
    Part number 03G 130 073 D
    Have the injector to head contact faces been inspected for damage?
  6. Re: A3 2.0 TDI Quattro DPF issues
    Mar 2015
    Hi Basher, I have some images ill try to share them:
    Audi Injectors - Google Drive
  7. Re: A3 2.0 TDI Quattro DPF issues
    1840 Post(s)
    I can't see any numbers....
  8. Re: A3 2.0 TDI Quattro DPF issues
    Mar 2015
    Morning Basher,
    The injectors in the images are the ones installed by Guildford Audi 4 years ago.. they were swapped as part of a recall..
    When those images were taken the Specialist at the time did check them and confirmed they were the new type... They were sent off and tested and referburshed... came back as not fault found and within tolerance.. were cleaned and had new seals installed.
    I couldnt see any scoring on the bottom of the head holes nor below the lower seal on each of the injectors..
    Does this help you for a possible diagnosis?
    Kind Regards
    Neil
  9. Re: A3 2.0 TDI Quattro DPF issues
    1840 Post(s)
    When the DPF light comes on, what is the code that is logged?
  10. Re: A3 2.0 TDI Quattro DPF issues
    Mar 2015
    When the DPF light comes on, what is the code this is logged?
    008194 - Particulate Trap Bank 1
    P2002 - 006 - Efficiency Below Threshold - MIL ON
  1. 2006 golf gt tdi dpf issues and warning lights please help!
    By golf170dpf in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2013, 12:15 AM
  2. 1.9, 2.0, 3.0 Tdi and potential for DPF issues
    By Pbro in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-11-2012, 09:33 PM
  3. Please Help A4 2.0 TDI 170 DPF Issues & Rough Idle
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 08:48 AM
  4. DPF in 2.0 tdi or just 1.9?and what issues to look out for?
    By Mike McKinstry in forum Golf MK5 - 2004 - 2009
    Last Post: 02-10-2011, 07:18 AM
  5. Question DPF ON 3.0 tdi quattro??
    By acabucca in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2010, 07:31 PM
