Thread: A3 2.0 TDI Quattro DPF issues
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. Re: A3 2.0 TDI Quattro DPF issues
    #21
    Mar 2015
    Fleet, Hampshire, United Kingdom
    Quote Originally Posted by FLAPPERJACK76 View Post
    That's better. What year and engine code is your vehicle.
    Sent from my SM-G900F using Tapatalk
    Its an 07 code ..... BMN
  2. Re: A3 2.0 TDI Quattro DPF issues
    #22
    Dec 2014
    Bedford
    42 Post(s)
    Ok you will have 3 exhaust gas temperature sensors. Get all 3 temperature readings. If one is wrong it will not regenerate. One before turbo. 2 before dpf 3 after dpf
  3. Re: A3 2.0 TDI Quattro DPF issues
    #23
    Mar 2015
    do you know which measuring blocks are used for the 3 ?
  4. Re: A3 2.0 TDI Quattro DPF issues
    #24
    Dec 2014
    Bedford
    42 Post(s)
    No but it will be around half way down. They will be close to each other. I'm more used to using odis (dealer diagnostic equipment )
  5. Re: A3 2.0 TDI Quattro DPF issues
    #25
    Mar 2015
    Address 01: Engine (03G 906 018 DN)
    20:15:18
    2038 /min Engine Speed (G28)
    36.0°C Coolant Temperature (G62)
    27.0°C Oil Temperature
    36.0°C Coolant Temp. Engine Outlet
    12.0°C Intake Air Temperature (G42)
    152.4°C Temperature bef. Turbo Charger
    97.5°C Temperatur in Particle Filter
    102.0°C Temperature bef. Particle Filter
    80.4°C Temperature after Particle Filter
    20:16:02
    819 /min Engine Speed (G28)
    41.0°C Coolant Temperature (G62)
    30.0°C Oil Temperature
    41.0°C Coolant Temp. Engine Outlet
    13.0°C Intake Air Temperature (G42)
    130.4°C Temperature bef. Turbo Charger
    111.6°C Temperatur in Particle Filter
    108.6°C Temperature bef. Particle Filter
    91.2°C Temperature after Particle Filter
    20:16:08
    820 /min Engine Speed (G28)
    126.0°C Temperature bef. Turbo Charger
    109.2°C Temperatur in Particle Filter
    106.5°C Temperature bef. Particle Filter
    89.1°C Temperature after Particle Filter
    20:16:16
    42.0°C Coolant Temperature (G62)
    31.0°C Oil Temperature
    42.0°C Coolant Temp. Engine Outlet
    121.8°C Temperature bef. Turbo Charger
    107.2°C Temperatur in Particle Filter
    20:17:46
    815 /min Engine Speed (G28)
    34.0°C Oil Temperature
    14.0°C Intake Air Temperature (G42)
    117.3°C Temperature bef. Turbo Charger
    102.7°C Temperatur in Particle Filter
    95.6°C Temperature bef. Particle Filter
    86.9°C Temperature after Particle Filter
    20:18:00
    821 /min Engine Speed (G28)
    35.0°C Oil Temperature
    20:19:57
    1910 /min Engine Speed (G28)
    48.0°C Coolant Temperature (G62)
    39.0°C Oil Temperature
    48.0°C Coolant Temp. Engine Outlet
    15.0°C Intake Air Temperature (G42)
    162.0°C Temperature bef. Turbo Charger
    120.4°C Temperatur in Particle Filter
    121.8°C Temperature bef. Particle Filter
    102.0°C Temperature after Particle Filter
    20:20:17
    1932 /min Engine Speed (G28)
    49.0°C Coolant Temperature (G62)
    41.0°C Oil Temperature
    49.0°C Coolant Temp. Engine Outlet
    16.0°C Intake Air Temperature (G42)
    123.0°C Temperatur in Particle Filter
    106.5°C Temperature after Particle Filter
    20:20:36
    1897 /min Engine Speed (G28)
    50.0°C Coolant Temperature (G62)
    42.0°C Oil Temperature
    50.0°C Coolant Temp. Engine Outlet
    17.0°C Intake Air Temperature (G42)
    159.5°C Temperature bef. Turbo Charger
    125.0°C Temperatur in Particle Filter
    123.9°C Temperature bef. Particle Filter
    108.6°C Temperature after Particle Filter
    20:21:21
    1820 /min Engine Speed (G28)
    52.0°C Coolant Temperature (G62)
    44.0°C Oil Temperature
    52.0°C Coolant Temp. Engine Outlet
    126.7°C Temperatur in Particle Filter
    110.7°C Temperature after Particle Filter
    20:22:44
    798 /min Engine Speed (G28)
    55.0°C Coolant Temperature (G62)
    47.0°C Oil Temperature
    55.0°C Coolant Temp. Engine Outlet
    123.9°C Temperature bef. Turbo Charger
    110.7°C Temperature bef. Particle Filter
    20:22:44
  6. Re: A3 2.0 TDI Quattro DPF issues
    #26
    Mar 2015
    Its worth a note here that on the last run i did in the car last night, I used the forced regen or 21295 code to ensure it was in regen mode whilst driving...
    The temp before turbo gets up to 800 degrees... its just that as soon as it is out of regen ( when it get down to 15% and all the lights go out ) the dpf coeffiecient % climbs up again... and in last nights run ... it didnt get below 18%
  7. Re: A3 2.0 TDI Quattro DPF issues
    #27
    Dec 2014
    Bedford
    42 Post(s)
    Ok do it once more in the morning on a stone cold engine with ignition on and engine not running. Although every temperature is looking good in those scans. Then post that.
  8. Re: A3 2.0 TDI Quattro DPF issues
    #28
    Mar 2015
    OK will do.
  9. Re: A3 2.0 TDI Quattro DPF issues
    #29
    1840 Post(s)
    The sensor is correct, do you know if it was calibrated? What is the DPF Ash Mass figure?
  10. Re: A3 2.0 TDI Quattro DPF issues
    #30
    Mar 2015
    Quote Originally Posted by Neil Hutchinson View Post
    OK will do.
    Group 75 - Field 0 Group 75 - Field 1 Group 75 - Field 3
    Temperature bef. - Turbo Charger Temperature bef. - Particle Filter Temperature after - Particle Filter
    °C °C °C
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    3.5 1.7 1.7
    8.9 1.7 1.7
    8.9 1.7 1.7
    8.9 1.7 1.7
    12.5 3.5 1.7
    36.5 10.7 1.7
    44.2 12.5 1.7
    52.2 16 1.7
    63 17.8 1.7
    73.8 21.4 1.7
    82.6 23.2 1.7
    86.9 25 1.7
    91.2 26.8 1.7
    95.6 26.8 1.7
    100 28.8 1.7
    102 30.6 1.7
    106.5 32.6 1.7
    108.6 32.6 1.7
    108.6 34.6 1.7
    110.7 36.5 3.5
    113 38.4 3.5
    113 40.3 3.5
    115.2 40.3 3.5
    115.2 40.3 3.5
    115.2 42.3 5.3
    117.3 42.3 5.3
    117.3 42.3 5.3
    117.3 44.2 5.3
    117.3 44.2 5.3
    117.3 44.2 5.3
    117.3 44.2 7.1
    117.3 44.2 7.1
    117.3 46 7.1
    117.3 46 8.9
    119.5 46 8.9
    119.5 46 8.9
    119.5 46 8.9
    119.5 46 8.9
    119.5 48 10.7
    119.5 48 10.7
    119.5 48 10.7
    119.5 48 10.7
    119.5 48 12.5
    119.5 48 12.5
    119.5 50 12.5
    119.5 50 12.5
    119.5 50 14.2
    119.5 50 14.2
    119.5 50 14.2
    119.5 50 14.2
    119.5 50 14.2
    119.5 50 14.2
    119.5 52.2 16
    117.3 52.2 16
    117.3 52.2 16
    117.3 52.2 16
    117.3 52.2 16
    117.3 52.2 16
    117.3 52.2 16
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 54.3 17.8
    117.3 56.5 19.6
    115.2 56.5 19.6
    115.2 56.5 19.6
    115.2 56.5 19.6
    115.2 56.5 19.6
    113 56.5 19.6
    113 56.5 19.6
    113 56.5 19.6
    113 56.5 19.6
    113 56.5 19.6
    113 56.5 19.6
    110.7 56.5 19.6
    110.7 58.5 19.6
    110.7 58.5 21.4
    110.7 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 21.4
    110.7 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 21.4
    108.6 58.5 23.2
    106.5 58.5 23.2
    106.5 60.8 23.2
    106.5 60.8 23.2
    106.5 60.8 23.2
    106.5 60.8 23.2
    104.3 60.8 23.2
    106.5 60.8 23.2
    104.3 60.8 23.2
    104.3 60.8 23.2
    106.5 60.8 23.2
    104.3 60.8 23.2
    104.3 60.8 23.2
    106.5 60.8 23.2
    104.3 60.8 23.2
    104.3 60.8 23.2
    104.3 60.8 23.2
    102 60.8 23.2
    102 60.8 23.2
    102 63 25
    102 63 25
    102 63 25
    102 63 25
    104.3 63 25
    104.3 63 25
    104.3 63 25
    106.5 63 25
    106.5 63 25
    106.5 63 25
    106.5 63 25
    108.6 63 25
    108.6 63 25
    108.6 63 25
    108.6 63 25
    108.6 63 25
    110.7 63 25
    110.7 63 25
    110.7 63 25
    110.7 63 25
    110.7 65.2 25
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    108.6 65.2 26.8
    108.6 65.2 26.8
    108.6 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    110.7 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    113 65.2 26.8
    115.2 67.2 26.8
    115.2 67.2 26.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    113 67.2 28.8
    113 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    113 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
    115.2 67.2 28.8
  1. 2006 golf gt tdi dpf issues and warning lights please help!
    By golf170dpf in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2013, 12:15 AM
  2. 1.9, 2.0, 3.0 Tdi and potential for DPF issues
    By Pbro in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-11-2012, 09:33 PM
  3. Please Help A4 2.0 TDI 170 DPF Issues & Rough Idle
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 08:48 AM
  4. DPF in 2.0 tdi or just 1.9?and what issues to look out for?
    By Mike McKinstry in forum Golf MK5 - 2004 - 2009
    Last Post: 02-10-2011, 07:18 AM
  5. Question DPF ON 3.0 tdi quattro??
    By acabucca in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2010, 07:31 PM
