Thread: A3 2.0 TDI Quattro DPF issues
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
  1. Re: A3 2.0 TDI Quattro DPF issues
    Mar 2015
    Fleet, Hampshire, United Kingdom
    Quote Originally Posted by Neil Hutchinson View Post
    008194 - Particulate Trap Bank 1
    P2002 - 006 - Efficiency Below Threshold - MIL ON
    Any ideas guys?
    I have just tried to get it out of limp mode and couldn't get under 18% on the coefficiant ... Only code logged is P2002 again.
    I have saved a CSV of the databanks if anyone is really bored.... and I can work out how to upload it here.
    It sould be noted that now the coil light is flashing as well as the dpf warning light.
  2. Re: A3 2.0 TDI Quattro DPF issues
    108 Post(s)
    1816 Post(s)
    18434 (P2002) - Particle Filter Bank 1: Malfunction
    What is the part number of the pressure sensor?
    Has the pressure sensor been calibrated and the learnt ASH mass values reduced accordingly when the DPF was cleaned? I normally set it at 25% of max to be safe.
  3. Re: A3 2.0 TDI Quattro DPF issues
    Dec 2014
    Bedford
    42 Post(s)
    If the dpf offset value is 0 it should regen. Worth checking by sucking on the hoses from the dpf pressure sensor to make sure that the offset value changes. Like Crasher is hinting must have the correct dpf pressure sensor as some work on a 3 volt scale and some work on a 5 volt scale. Always check in mvbs that the sensor temperature is believable check all of them from cold and they should all be around ambient.
    Sent from my SM-G900F using Tapatalk
  4. Re: A3 2.0 TDI Quattro DPF issues
    108 Post(s)
    1816 Post(s)
    The pressure sensor is making my nose itch, suspicious...
  5. Re: A3 2.0 TDI Quattro DPF issues
    Mar 2015
    Quote Originally Posted by FLAPPERJACK76 View Post
    Hi all:
    So from cold and I mean COLD brrrr: Engine off and ambient is about 5 degrees (checked coolant temp on vcds )
    Temp B4 Turbo: 9.8 deg
    Temp in Dpf: 15.4 deg
    dpfmbar:0
    0ffset:1
    After circa 5 mins running at idle :
    Temp B4 Turbo: 102.0 deg
    Temp in Dpf: 87.2 deg
    dpfmbar:13
    0ffset:1
    The Sensor is part 1k0905283a
    When I removed the hose on the right as your are looking from the front of the car there was a vacuum present,
    When I removed the hose on the left no vacuum or pressure felt
    Both hoses visually look clean and clear internally.
    I was ensured that when the sensor was swapped : it has been done twice : that it was encoded.
  6. Re: A3 2.0 TDI Quattro DPF issues
    Dec 2014
    Bedford
    42 Post(s)
    That's not a dpf pressure sensor. It has 2 hoses going directly to the dpf also known as a g450 the hoses are about 10 to 12mm in diameter. That looks like a n75 valve.
  7. Re: A3 2.0 TDI Quattro DPF issues
    #17
    Dec 2014
    Bedford
    42 Post(s)
  8. Re: A3 2.0 TDI Quattro DPF issues
    #18
    Dec 2014
    Bedford
    42 Post(s)
    This is a dpf pressure sensor.
  9. Re: A3 2.0 TDI Quattro DPF issues
    #19
    Mar 2015
    Balls Wrong image .... Part is 076 906 051a
  10. Re: A3 2.0 TDI Quattro DPF issues
    #20
    Dec 2014
    Bedford
    42 Post(s)
    That's better. What year and engine code is your vehicle.
  1. 2006 golf gt tdi dpf issues and warning lights please help!
    By golf170dpf in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2013, 12:15 AM
  2. 1.9, 2.0, 3.0 Tdi and potential for DPF issues
    By Pbro in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-11-2012, 09:33 PM
  3. Please Help A4 2.0 TDI 170 DPF Issues & Rough Idle
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 08:48 AM
  4. DPF in 2.0 tdi or just 1.9?and what issues to look out for?
    By Mike McKinstry in forum Golf MK5 - 2004 - 2009
    Last Post: 02-10-2011, 07:18 AM
  5. Question DPF ON 3.0 tdi quattro??
    By acabucca in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2010, 07:31 PM
