Thread: Help - slow death; white smoke on start, then stalls; growls on load
  1. Help - slow death; white smoke on start, then stalls; growls on load
    Mar 2008
    In Audi A6 C5.
    Since cold weather of last few weeks, power problems progressively worsening.
    Now, starts reliably, but within a minute stalls when applying accelerator; if left to idle, white smoke increases. Consequently have abandoned use for fear of getting stranded.
    Before all this it had started to stall in traffic and once or twice seemed to lose turbo power.
    When these problems got worse, engine would occasionally growl with acceleration giving zero extra power, although if given legs power was there as normal.
    Had fuelled with BP Ultimate last 100 litres, although this coincided with colder weather.
    Any help gratefully received.
  2. Re: Help - slow death; white smoke on start, then stalls; growls on load
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    You need to get it scanned for fault codes, then post them with the three letter engine code and details of servicing and any engine related repairs, this code is on the car data page in the service book or the boot sticker. any diagnosis or recommendation to fix/change any parts is guess work until you get it scanned. the fault could any of several engine sensors, or a mechanical problem; dirty fuel filter, worn tandem pump, in tank fuel pump etc.
  3. Re: Help - slow death; white smoke on start, then stalls; growls on load
    Mar 2008
    Thank you for your reply, I got a mechanic out who determined that the exhaust was congested at the head end (removing it at the engine connection solved the stalling issue)
  1. White/Grey Smoke on Cold Start, Black/Grey Smoke on Hot Start
    By PD_Probs in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-10-2016, 08:26 AM
  2. Question White Smoke on Start up
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2015, 09:09 PM
  3. white smoke on start up
    By steve02 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-01-2012, 01:49 PM
  4. Please Help White smoke on start up
    Last Post: 27-12-2011, 03:56 PM
  5. White smoke on start up.
    By carnage355 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-09-2009, 08:44 PM
