Thread: Side Assist / Exit Warning / Rear Traffic RetroFit
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 76
  1. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #31
    Mar 2010
    37 Post(s)
    228 Post(s)
    Lol...
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  2. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #32
    Mar 2010
    37 Post(s)
    228 Post(s)
    Final update.
    Managed to get round to doing drivers side door mirror this weekend. Now all complete. Everything working as it should and tested. Really pleased.
    Hope its been of interest.
    Andy
    0 3 0
  3. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #33
    Mar 2010
    37 Post(s)
    228 Post(s)
    An absolutely bargain for the rear radar sensors and loom if anyone is interested...
    Org Audi A4 8W Q7 4M Steuergeräte Set Spurwechselassistent 4M0907566 4M0907590 | eBay
  4. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #34
    That didn't hang around for long...
  5. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #35
    Mar 2010
    37 Post(s)
    228 Post(s)
    Jeez.. Your not kidding
  6. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #36
    Sep 2017
    Voorburg The Netherlands
    @andyhud007
    really great job! I did the same with my A3 8V FL but i am figuring some coding out..can you help me?
    Do i need to code module 10(park assist) for the audible alert when RTCA is activated?
    Also do you know what to code in ABS for the brake jolt?
    So far i know is that the 8V FL does not have exit warning alerts. The A4 and A5 do have it
  7. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #37
    Mar 2010
    37 Post(s)
    228 Post(s)
    Rainesh, best pm. Me directly. I'm not sure if the coding from a q7 4m is same to an an A3 8v. I do know I didn't change anything in my abs module, just the mmi and door controllers
    Cheers.
    Andy
    Sent from my SM-G928F using Tapatalk
  8. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #38
    Sep 2017
    Encinas Reales
    So apparently everything went well, could you give some details of the configuration and the electrical connections?
  9. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #39
    Mar 2010
    37 Post(s)
    228 Post(s)
    Sorry, its impossible to share that as it depends on your current car configuration and there is just too much to openly share online
  10. Re: Side Assist / Exit Warning / Rear Traffic RetroFit
    #40
    Jan 2018
    Warsaw
    65 Post(s)
    Hi Andy,
    I am new on this forum found it digging for some info about Q7 retrofit. I am an owner of Q7 4m 3.0TDI with reinforced engine to 325HP. Couple month ago I have retrofitted my car with Side Assist set. Side Assist as well as Rear Traffic Warning work perfectly but Exit Warning doesn't work at all. I was told to change in Module 09, Byte 37, Bit 0 from 0 on 1 ( I use VCP) but it didn't help.
    I already have found out that I have to install LED Modules (4M0 947 536D), some harness and do the proper coding.
    And now my big and kind request to you. It seems that you can help:
    1/ How should I wire it?
    2/ What is the proper coding of Exit Warning assuming that Side Assist and Rear Traffic Warning is already installed and work.
    3/ Is there something more to do to make it working?
    I would appreciate your help
    Best regards
  1. Demonstration Video of Exit warning
    By Papereyes in forum Q7 - 4M Forum - 2016 -
    Last Post: 13-09-2016, 07:24 AM
  2. Anyone used Traffic Jam Assist?
    By elrao in forum Q7 - 4M Forum - 2016 -
    Last Post: 31-03-2016, 09:52 PM
  3. Park Assist and Side Assist coding.
    By sany98 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-05-2015, 02:42 PM
  4. Retrofit Lane assist
    By soft in forum A7 - S7
    Last Post: 28-05-2014, 08:06 AM
  5. Question Rear OEM park assist retrofit
    By stan_man in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2013, 05:24 PM
