Thread: Huge list of fault codes, all in one go, won't go away!
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Huge list of fault codes, all in one go, won't go away!
    Nov 2016
    Cumbria
    Nothing. Few crispy dry leaves.
  2. Re: Huge list of fault codes, all in one go, won't go away!
    Nov 2016
    Cumbria
    I can't understand how I went from a bunch of faults and a slightly flat battery. To a full new battery and a car that just turns over.
  3. Re: Huge list of fault codes, all in one go, won't go away!
    Oct 2005
    Are there any new faults now you've changed the battery?
  4. Re: Huge list of fault codes, all in one go, won't go away!
    Nov 2016
    Cumbria
    No :/
  5. Re: Huge list of fault codes, all in one go, won't go away!
    Nov 2016
    Cumbria
    Ok I've found a blown fuse. 10amp no42 I think. Replaced it. All my faults have gone. But still won't start?
  6. Re: Huge list of fault codes, all in one go, won't go away!
    Nov 2016
    Cumbria
    Fuse 10
  7. Re: Huge list of fault codes, all in one go, won't go away!
    #17
    Oct 2005
    There are two fuse boxes on the Touareg, one in the plenum area and one at the end of the dash.
    In the plenum area, fuse 10 (10A) is for;
    G65 - High Pressure Sensor
    J17 - Fuel Pump (FP) Relay
    J179 - Automatic Glow Time Control Module
    J255 - Climatronic Control Module
    J293 - Coolant Fan Control (FC) Control Module
    J301 - A/C Control Module
    J442 - Generator Switch-in Relay ¹)
    J445 - Fuel Cooling Pump/Relay
    J496 - Auxiliary Engine Coolant (EC) Pump Relay
    J671 - Coolant Fan Control (FC) Control Module 2
    J724 - Turbocharger (TC) 1 Control Module
    N18 - EGR Vacuum Regulator Solenoid Valve
    N280 - A/C Compressor Regulator Valve
    N345 - Exhaust Gas Recirculation (EGR) Cooler Switch-Over Valve
    V157 - Intake Flap Motor
    V275 - Intake Flap Motor 2
    In the dash, fuse 10 (30A) is for;
    J388 - Left Rear Door Control Module (window regulator)
  8. Re: Huge list of fault codes, all in one go, won't go away!
    #18
    Nov 2016
    Cumbria
    It was the one in the plenum area. As soon as I replaced it I was able to clear the faults. A little sniff of brake cleaner in the air intake and it sprang into life. It's running fine now, no faults.
    0 4 0
  1. List of fault codes for VAG - Com
    By BDT in forum VCDS - General Questions
    Last Post: 09-10-2013, 11:16 AM
  2. VCDS Codes list for Ibiza 6L type MK4
    By shivy in forum Ibiza - Cordoba
    Last Post: 14-05-2012, 09:43 PM
  3. VCDS Codes list for Ibiza 6L type MK4
    By shivy in forum VCDS - General Questions
    Last Post: 14-11-2011, 12:19 AM
  4. Option Codes - Not a complete list!
    By MFGF in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-10-2009, 11:15 PM
  5. vag com codes list
    By leckford in forum Archive posts
    Last Post: 30-07-2007, 05:56 PM
