Thread: Question about vacuum.
  1. Question about vacuum.
    Oct 2016
    Jonava Lithuania
    Hello, is it possible that check valve between vacuum reservoir and N75 valve cousing low boost and sometimes hard brakes? Tandem not leaking and brake booster hose checked they are okey.
  2. Re: Question about vacuum.
    Pembrokeshire
    22 Post(s)
    remove the small pipe and blank the big pipe from just next to the tandem pump and see if the brakes are better. you cant drive like this, just do it stationary, pump pedal, should get a few pumps before it goes hard. now use some pipe and go from the same place direct to the turbo. the actuator should move straight up into max boost position. if it does, then re do the piping to take the egr and asv solonoids out the circuit. so straight from the small pipe coming off the tandem , straight to the n75 and straight down to the turbo. now go for a drive and see if this helps.
  3. Re: Question about vacuum.
    Oct 2016
    Jonava Lithuania
    Thanks gonna try this tommorow
  4. Re: Question about vacuum.
    Pembrokeshire
    22 Post(s)
    i had one the other week, a golf that was underboosting. testing the tandem pump showed it had vacuum, 20 inhg, but would fall and not build up quick enough. stripping the pump showed the inside all scored, so a new pump was fitted. this cured the poor brakes but still underboosted. we then fitted a new n75 valve. this didnt help until it was plumbed in direct without the other 2 valves. re fitting the old n75 this way and it went back to underboost. so it was a combination of a few things that had been wearing out over the years.
  5. Re: Question about vacuum.
    Oct 2016
    Jonava Lithuania
    Maybe your solenoids were leaking. Found some information on internet that the black/white one way valve can couse underboost too if its broke
  6. Re: Question about vacuum.
    Pembrokeshire
    22 Post(s)
    something was leaking, he took the car away to make sure it was ok and not been back since so must be ok. whatever it was, it was difficult to find. well, one day i will find it.
  1. Question Vacuum Unit - when is a vacuum pipe necessary?
    By geoffreytro in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2014, 01:39 AM
  2. Please Help 2.5 V6 TDI Vacuum Question
    By Chiefwiggum in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2011, 07:51 PM
  3. vacuum pipes
    By crunchynutter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2010, 08:15 PM
  4. Vacuum ??
    By Redzer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-09-2008, 08:22 AM
  5. Vacuum Leak
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2008, 10:40 PM
