Thread: Auto tilting passenger side window not working on 2nd Key when reversing
Results 1 to 10 of 10
  1. Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2016
    KEnt
    22 Post(s)
    Just wanted to double check this isn't a function I'm missing in the MMI.
    I've begun to notice that when I drive with my wifes key, when I put the car in reverse the passenger window doesn't tilt properly when I put it into reverse, so it doesn't point to the kerb (even thought the rear view mirror is set pointing towards the passenger side.)
    However, when I drive the car with my key and I put the car into reverse the passenger side window tilts to point towards to kerb so it works properly
    Reckon this is a bug which i need to take to the dealer? or is there a setting in the MMI which you need to turn on?
  2. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2016
    11 Post(s)
    You have to store the tilt position for each key separately. It's a feature.
  3. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Apr 2016
    Stansted
    169 Post(s)
    I'm sure this is an easy fix as it rings a bell!
    With wifes key, put it in reverse and then adjust the mirror to point down the amount you want and then it should remember it.
    I has similar issue the other day where my setting was pointing down too much. I'm sure this is the fix and no need for a dealer visit.
  4. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Jul 2010
    uk
    183 Post(s)
    Quote Originally Posted by srbsq7 View Post
    Exactly what I had to do - well the wife did, so shouldn't be an issue
  5. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2016
    KEnt
    22 Post(s)
    Quote Originally Posted by Nemo78 View Post
    Thanks chaps just tried it now, so works when I put it in reverse and the mirror tilts. However, when I put it in drive the mirror doesn't return back to the normal setting and instead just remains pointed at the kerb.
    Then tried the reverse option of adjusting mirror in drive to its Norma position, but doesn't point to kerb when reversing.
  6. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2016
    London
    Quote Originally Posted by Papereyes View Post
    Just checking but you did drive off to see if the mirror returns to normal position? Just putting the car in drive will not bring the mirror to the normal position.
  7. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2010
    37 Post(s)
    228 Post(s)
    What jake said. You need to drive off for it to return to normal position. Think it's as car goes over 5mph-ish
  8. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2016
    KEnt
    22 Post(s)
    Yup your right, just tried it now thanks chaps
  9. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    May 2017
    Australia
    28 Post(s)
    I know I'm a bit late to the convo but thought i might add my 2cents, My 2016 q7 will only tilt if i leave the mirror adjuster knob selected on the mirror i want to tilt while reversing, so i always leave it selected on the left mirror and everytime i select reverse it tilts but if i dont have it selected then it doesn't move. Instantly moves back to normal position when drive gear is selected and doesn't require the car to be in motion.
    Sent from my SM-G935F using Tapatalk
  10. Re: Auto tilting passenger side window not working on 2nd Key when reversing
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by Tezargh View Post
    This is normal operation. Wing mirror selector must be on passenger wing mirror for reverse Tilt to work. Been like that for years on audis.
    Hth
    Andy
    Sent from my SM-G928F using Tapatalk
  1. Please Help Passenger side window and door not working/locking!!?
    By Benprice8784 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-02-2015, 03:43 PM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. Passenger side electric window
    By jalz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-04-2010, 03:44 AM
  4. Replies: 1
    Last Post: 25-05-2009, 10:52 AM
  5. Passenger side electric window
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2007, 06:00 PM
