Thread: My '03 Audi Allroad project
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
  1. Re: My '03 Audi Allroad project
    Nov 2016
    Swindon
    13 Post(s)
    Cabin filter tray removed, the area has been cleaned and a new one (with a new filter) has been fitted back. Spent some time drying the carpet. Job 1 done
  2. Re: My '03 Audi Allroad project
    Nov 2016
    Swindon
    13 Post(s)
    Suspension air compresor removed from the car, the metal guard had corroded badly and almost disintegrated, but once I opened the compresor, the cylinder is clean and scratch free and the piston ring have a slight taper, so I am pretty confident the repair kit is going to work
    I need to source a new metal guard / compressor cover (are them expensive?), nuts and the clips for the intake hose. Do you know what is the p/n for the rubber band that holds the air compresor silencer in place? I found this picture showing the band.
    Best regards.
  3. Re: My '03 Audi Allroad project
    Nov 2016
    Swindon
    13 Post(s)
    Quote Originally Posted by Chema.RB View Post
    Passenger footwell was flooded, and one of the connectors to the CCM was already changed. The CCM was in pretty good shape, but was not possible to connect to module 35, or to code the remote. It seems is not the right CCM for the car, it's an 4B0962258N but it should be a 4B0962258H or 4B0962258K. I need to doublecheck this before sourcing one. (and dry the footwell)
    I have been checking at it seems the 4B0962258N is indeed the right CCM for my car. Any idea why I can't sync the fob and also I can't connect for diagnostics?
  4. Re: My '03 Audi Allroad project
    Nov 2016
    Swindon
    13 Post(s)
    Changed the CCM module for another one... and I cannot connect!! When I try to connect, I have hear a relay clicking (both in the old and the new) and the interior lights flickers twice. Maybe the connector wasn-t properly changed. I will try to source one and try again.
  5. Re: My '03 Audi Allroad project
    Ayrshire, Scotland
    18 Post(s)
    Was the module new or 2nd hand?
    Check wiring for corrosion
    Best regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  6. Re: My '03 Audi Allroad project
    Nov 2016
    Swindon
    13 Post(s)
    Hi Andi,
    It was an used module, and does exactly the same as mine: PCB is squeaky clean, no corrosion, but when I try to connect with module 35, you can hear a relay clicking twice and interior lights flickers. The "power" connector (I thing is connector number 1) has been replaced in the past, all the wires coming out are yellow, and it's been soldered to the loom, but they used electric tape to insulate them.
    This weeked it's time to remove passenger seat and give a good look at the loom under the carpet.
  7. Re: My '03 Audi Allroad project
    #17
    Ayrshire, Scotland
    18 Post(s)
    Yep remove tape and check joints, if they have been in the water I suspect a few need to be cleaned and re-joined
  8. Re: My '03 Audi Allroad project
    #18
    Nov 2016
    Swindon
    13 Post(s)
    Removed seats, rear centre console and lifted carpet, found a few more corroded cable junctions. In the point where multiple cables joins (+12 volt cables, probably), cables are joined with a copper ring. I tried soldering, but it's very complicated due to the diameter of the cables.
    Can these copper rings be sourced?
  9. Re: My '03 Audi Allroad project
    #19
    Ayrshire, Scotland
    18 Post(s)
    I'm not sure of them, do you have a photo?
  10. Re: My '03 Audi Allroad project
    #20
    Nov 2016
    Swindon
    13 Post(s)
    Of course
  1. Please Help Project Allroad -- Engine Doesn't Start -- Zero Compression Cyl 4/6
    By chillax in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2016, 01:16 PM
  2. Potential Audi A4 Project..
    By KrishanK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2014, 07:20 PM
  3. Audi 100 resurection project
    By Kr0mulous in forum 100 - 200 - Turbo - 100 S4
    Last Post: 28-04-2009, 08:58 PM
  4. Hello! Audi 80 coupe project
    By ferret in forum New Member Introductions
    Last Post: 06-01-2008, 10:41 PM
