Thread: Oil pressure failure after oil pump change
Results 11 to 20 of 25
  1. Re: Oil pressure failure after oil pump change
    1840 Post(s)
    7 Bar at 2K at 80 degrees+ is very strong, almost too much. Do you have the part number of the new switch they fitted?
  2. Re: Oil pressure failure after oil pump change
    Nov 2016
    Sherborne
    Sorry not to hand. I have just ask them to email it too me. I though 7 bar seem quite strong...perhaps too much sets it off too?
  3. Re: Oil pressure failure after oil pump change
    Nov 2016
    Sherborne
    I'm told its part number is "03G 115 105 H" from the search I just did, it appear to be OEM an part.
  4. Re: Oil pressure failure after oil pump change
    1840 Post(s)
    I am assuming your engine is a CBAB. 03G 115 105 H is the part number of the oil pump.
  5. Re: Oil pressure failure after oil pump change
    Nov 2016
    Sherborne
    Yes its a CBAB model. ANy suggstions on a way forward would be greatfully appreciated...running out of ideas!!!
  6. Re: Oil pressure failure after oil pump change
    1840 Post(s)
    I need the part number of the new oil pressure switch that they have fitted.
  7. Re: Oil pressure failure after oil pump change
    #17
    Dec 2010
    Worcs, UK
    7 bars???
    Seems quite a bit too high if you ask me?
    Sent from my D5503 using Tapatalk
  8. Re: Oil pressure failure after oil pump change
    #18
    Nov 2016
    Sherborne
    I'll ask, I think they are open tomorrow. Any other details while i'm asking?
  9. Re: Oil pressure failure after oil pump change
    #19
    1840 Post(s)
    I would be more sure if I was convinced about their oil pressure readings
  10. Re: Oil pressure failure after oil pump change
    #20
    Nov 2016
    Sherborne
    Not sure what more todo other than trust that they have it right
  1. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  2. Engine burning oil after timing belt slip + oil pump change
    By steve_v1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2016, 03:22 PM
  3. Oil pump failure
    By PajeroGolf in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2015, 07:40 AM
  4. oil pump failure
    By passat 130 tdi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-08-2013, 04:45 PM
  5. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
