Thread: Brake Pad light
Results 1 to 10 of 11
  1. Brake Pad light
    Dec 2015
    London
    13 Post(s)
    So.. I've had this coming up since of late,
    Checked it out with a mechanic who thought it was the front brakes.
    Replaced yesterday inclusive of the wear sensor, DIY, but the brake pad warning is still on
    Does this need to be reset via VCDS.. or is this saying it's perhaps the rear brakes?
    Any thoughts appreciated pls.
    Thx, J
  2. Re: Brake Pad light
    May 2013
    Wisbech
    8 Post(s)
    more likely rear as they are thinner than front.
    there is no need to vcds to reset light
    Sent from my Nexus 6P using Tapatalk
  3. Brake Pad light
    Dec 2015
    London
    13 Post(s)
    My suspicion is the same.. also brake pad warning light comes up only when I start moving the car, i.e. Probably when it satisfies a sensory condition.
    Can anyone with experience confirm whether brake pad warning needs to be reset pls?
    Thx, J
  4. Re: Brake Pad light
    May 2013
    Wisbech
    8 Post(s)
    I have done this on A8, no need for front. just for rear in some case, depending on parking brake module type
  5. Re: Brake Pad light
    Feb 2013
    Gloucester
    57 Post(s)
    Good to know the rears have sensors as mine were low on its recent MOT.
    As far as I know it's a wire in the pad which wears through so shouldn't need resetting on Vcds.
  6. Re: Brake Pad light
    Dec 2015
    London
    13 Post(s)
    Rears have sensors as per Elsawin.
    Yeah that's what I'd expect too..
    Sounds like I'd change rears and see, they were worn out too, only thing was the mechanic thought fronts were worse off, maybe he got it wrong in the first place.
  7. Re: Brake Pad light
    May 2013
    Wisbech
    8 Post(s)
    rear only needs putting thickness of pad in epb in some modules, which I'm 90% sure they are not used in A7 and A8.
    As you said mitchy the indication for brake pad light is wire in pads, and nothing else. just swap wire and it will be all fine
  8. Brake Pad light
    Dec 2015
    London
    13 Post(s)
    As per Elsawin sounds like I need VCDS to retract the handbrake for rears?
    Isn't there any other way, I don't have VCDS
    J
  9. Re: Brake Pad light
    May 2013
    Wisbech
    8 Post(s)
    yes u need vcds, sorry, I quote my procedure from different forum
    Code:
    i have changed front and rear.*
    front: no issues, just to remember wear sensors are not icluded in set, luckily mine sensors were ok, you can buy them seperate for cost of around £8. changing procedure as any other braking system, release 2 caliper nuts and one on outer side of caliper. caliper will come off, change pads and put everything back together.*
    rear:*release parking brake - in vcds, controller 53(parking brake) -my controller is working in UDS protocol - so go to basic settings - from drop down list choose 'start linning change procedure' - you will hear parking brake winding all way back and screen shows 'running' - once screen shows 'not running' - go out from controller- close vcds - turn off ignition - you will notice parking brake button and 'P' on dash will flash - also don't worry if during changing process both lights stop flashing, it is energy saving feature. - next thing changing pads - well piece of cake- remove 2 nuts from back of caliper - and now before you remove caliper - use flat bar or big flat screwdriver put it in between old pad and caliper on outer side of wheel hub and pry on it and your piston will go magically back and you don't have to use later any special tools and caliper will be ready to take any size of pads and new disc. i had both sensors broken on back and they are included with pads, swap them. after you changed rear pads on both wheels put ignition on press brake pedal few times until feels hard open vcds module 53 - basic setting - from list choose ' end of lining change process' you will hear again parking brake working again and wait until vdcs shows 'finished' - parking brake button and 'P' on dash stops flashing - engage parking brake through button then release and engage again - now in vcds go to 53 module erase all faults, if everything is done correctly, faults will be gone and won't come back- also go to module 08 abs clear all faults and to module 01 engine and clear all faults. go for ride and enjoy new pads. JOB DONE!*
    one thing - i forgot about brake fluid so when i push pistons back brake fluid came out through tank lid and went through drainage on driveway. as fluid is corrosive i used luke warm water with fairy liquid and washed tank and flushed drainage.*
    second thing - i didnt hook up battery charger for whole procedure but I advise you to do it.*
    i took us 40 minutes to do front and rear.
  10. Re: Brake Pad light
    Dec 2015
    London
    13 Post(s)
    All done, got vcds, did the brake job
  1. Brake pad Light on and the off
    By mabaudi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2015, 10:06 AM
  2. Brake Pad Warning Light On, How Far Can I Keep Going?
    By as400 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-12-2012, 06:47 PM
  3. Brake pad light
    By fulcrum111 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2010, 11:32 AM
  4. A3 Brake pad warning Light
    By samz77 in forum Audi A3 - Archive Topics
    Last Post: 23-01-2008, 02:24 PM
  5. Brake Pad warning light?
    By les in forum Passat - Archive Topics
    Last Post: 27-11-2006, 09:51 PM
