Thread: A4 b8 2.0tdi 105kW problem with coolant temperature
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
  1. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #31
    Dec 2008
    12 Post(s)
    If your car is facelift model there shouldn't be more than one thermostat. Where is second thermostat placed and which part number it has? As far as I know only preFL cars have two thermostats and one is hidden in rubber hose which connect oil cooler and exhaust gas cooler part number 03L 121 157 B
  2. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #32
    Nov 2017
    Slovenia
    Yes,
    Temperature on vcds is 85 C, odometer show 90 C. when I test whole odometer, all index finger came to max (also temperature), before hi isn't.
    and then he is in the middle, like others. I think that now is ok.
    But I don't know, why the temperature index finger in not in the correct position (manufacturer failure?)
    What was with him, when the car was new....
  3. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #33
    Nov 2017
    Slovenia
    no, my car is facelift, motor code CJCA. it has two termostat. On the block of motor and hose ....
  4. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #34
    Feb 2018
    TB
    I have the same problem with my Audi A4 Quattro 2013. 2.0 TDI 110 kW. My problem is started after the replacement timing belt and water pump. My car is facelift but still, have two thermostats. Both of them replaced. Now, I'm interested in return valve in the hose. Can anybody confirm what is a solution of the problem?
  5. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #35
    Nov 2017
    Slovenia
    Hello,
    Do you have return valve? My has only hose termostat (second termostat) without return valve... in what position is temperature index finger on the odometer when the ignition is off? It must be minimum at 50 0C
  6. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #36
    Feb 2018
    TB
    No. I'm looking for this return valve today. My car doesn't have this return valve. Can Audidua confirm solution of the problem?
  7. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #37
    Dec 2008
    12 Post(s)
    I dont know where no-return valve is on FL cars. Im looking for it on my A5 2.0tdi, found second thermostat only by now.
  8. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #38
    Feb 2018
    TB
    So, you didn't solve your problem? I think that return valve doesn't exist in facelift models. I can't see return valve in hoses in my car 2013. model. Only second thermostat.
  9. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #39
    Dec 2008
    12 Post(s)
    No, I didnt but I think it is normal behaviour when I on motorway temperature sits on 90 degrees and when I'm driving on local city streets and heating is set on 24°C there is a little oscilation on temp gauge where not sitting on 90. I'll leave it like that will not care anymore.
  10. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #40
    Feb 2018
    TB
    I'm freezing with 24ºC. If I set my heating on 26 ºC I feel a little heat only after 5-6 km. Temp outside is 8 - 13 ºC these days. It would be interesting to test our thermostats. Does it really open at 87 ºC or less?
  1. Please Help Coolant temperature sensor, emissions problem
    By Boogins in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-02-2016, 09:56 PM
  2. Question Audi a4 3.0tdi coolant temperature issue
    By nuty_bloke in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2015, 01:00 PM
  3. Please Help Coolant temperature sensor problem
    By kizzy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2014, 05:20 PM
  4. Air con, fan, coolant temperature guage problem.
    By guv.c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-06-2010, 11:29 AM
  5. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
