Thread: A4 b8 2.0tdi 105kW problem with coolant temperature
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
  1. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    Oct 2012
    Estonia
    64 Post(s)
    Good, now you can change hole hose, or just part of the hose, if regulator will not fix the issue, next one is return valve, which is also part of the same hose and you cant see this either.
    Good luck!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  2. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    Dec 2008
    12 Post(s)
    Thank you, I hope this will fix the issue.
  3. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    Oct 2012
    Estonia
    64 Post(s)
    Lets hope so, as the last guy on this russian link posted, he replaced both at the same time, so for him, no idea which was faulty!
    return valve separate number is:
    1J0122351(20 pound or something like that)
  4. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    Dec 2008
    12 Post(s)
    If I get it right number 1. is Regulator and number 2. is Return Valve?
  5. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    Oct 2012
    Estonia
    64 Post(s)
  6. A4 b8 2.0tdi 105kW problem with coolant temperature
    Dec 2008
    12 Post(s)
    Thank you, thank you, thank you...I would not fix this without your help.
    I've changed the thermostat only and all is fine now. Thermostat was payed about £15 and was without OEM part number and Audi logo because it is treated and sold like aftermarket part. If you want to purchase it in official service then the price is 3x higher.
  7. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #17
    Dec 2008
    12 Post(s)
    Here I am with some news about coolant temperature. After thermostat 1K0 121 113A changed all was fine but last few days I've noticed that the coolant temperature is dropping on cca 83 degrees celsius if I set the heating on HI or little bit less. If the heating is set to 25-26C then all is good no oscillations at all even on idle. Is it the return valve 1J0122351 the issue now?
  8. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #18
    Dec 2008
    12 Post(s)
  9. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #19
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by Audidua View Post
    I never tested any of my car like this, could be normal, especially for tdi engine. I would keep things as they are! Keep 20-25 and dont boil the egs
  10. Re: A4 b8 2.0tdi 105kW problem with coolant temperature
    #20
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If the engine is not working hard but gauge is sitting at 90' and you set the cabin heater to HI, a small drop in dashboard temperature is normal, especially we are now in lower ambient temperatures, does this happen if you are driving steady at say 2500rpm and then set heater to Hi?
  1. Please Help Coolant temperature sensor, emissions problem
    By Boogins in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-02-2016, 09:56 PM
  2. Question Audi a4 3.0tdi coolant temperature issue
    By nuty_bloke in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2015, 01:00 PM
  3. Please Help Coolant temperature sensor problem
    By kizzy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2014, 05:20 PM
  4. Air con, fan, coolant temperature guage problem.
    By guv.c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-06-2010, 11:29 AM
  5. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
