Thread: 1.8T Oil Burning/Leaking
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    So, one problem sorted, another one appears Fantastic lol.
    My 1.8T seems to be using about 800ML of oil every thousand miles..... which is roughly enough to take it from full on the dipstick, to low enough that the MIN symbol appears on the instrument cluster. That's a fairly high consumption (although I'm hoping as a side effect that it aids cleaning the engine lol).
    Now, to be fair, I have no idea what oil is in. If it's 5w30, it might far too thin, seeing as it's got 110k miles on the clock and it's a hot running engine. Still, I actually topped it up with 5w40 and it seems to have made no difference, just a few weeks later, the MIN light re-appears.
    Are there any common places to check for leaks? I know the oil cooler housing is one. However with all the undertray it's kind of hard to see from underneath, so I can only really inspect from above and by shoving my phone to the side, which I've done. There appears to be oil, but I can't tell if that's from the oil cooler or not.
    Nonetheless this is what I see from the side of the filter:
  2. Re: 1.8T Oil Burning/Leaking
    May 2012
    Everywhere
    308 Post(s)
    Definite leak there and get the undertray off and have a look and identify .
    What 5W40 did you put in ?
  3. Re: 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    Castrol Edge.
  4. Re: 1.8T Oil Burning/Leaking
    May 2012
    Everywhere
    308 Post(s)
    At 13 Centistokes @100°C it's never going to reduce consumption whilst the typical 5W30 504.00 is 12 Centistokes .
  5. Re: 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    Quote Originally Posted by Gazwould View Post
    I'm not entirely sure what you mean
  6. Re: 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    The leak appears to be coming from the right hand side of the engine block (drivers side UK). Might try get the under tray off today.
  7. Re: 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    Decided take it to kwik fit, get a free diagnosis. Wouldn't say they were much use. They said the entire engine is caked in oil, also the gearbox. It's not the turbo. They think it's coming from the top of the engine they think either a breather or rocker cover. I asked whether it could be PCV but he looked a tad confused. Not going to complain. Free half diagnosis I suppose. Not the turbo, yay.
    Anything coming to mind?
  8. Re: 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    Decided chance my arm at a Halfords for their free diagnosis.
    It's definitely the rocker cover gasket (or valve cover gasket for our American friends). They reckon it's leaking from their onto the coil packs and if I had removed the engine cover I'd have probably spotted it. To be fair, I couldn't really be bothered. Easier let those guys do the hard work, and I do the easy work of fixing it.
    Rocker cover it is. Let's see if I can get a genuine part before the weekend, otherwise it'll have to wait another week. Are aftermarket copies any good? Just I can get one from ECP very easily. Not so easy to get parts from Audi.
  9. Re: 1.8T Oil Burning/Leaking
    Aug 2016
    Stoke
    6 Post(s)
    Been reading it could be the VVT seal too? Is there any way of telling?
  10. Re: 1.8T Oil Burning/Leaking
    Nov 2013
    west midlands
    i had this engine in a golf the rocker cover gasket is a common issue. 800ml is alot though so it may be another issue also
  1. Engine burning oil after timing belt slip + oil pump change
    By steve_v1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2016, 03:22 PM
  2. Low oil warning, EGR valve leaking oil, burning oil smell - please help!
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2012, 01:51 PM
  3. Audi oil change costs and oil burning B8
    By Nabs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2010, 09:45 PM
  4. Please Help Oil Burning
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-09-2010, 10:20 PM
  5. burning oil
    By changtech in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-10-2006, 09:31 PM
