Thread: Somebody kill me now?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Somebody kill me now?
    Mar 2016
    Australia
    Changing out the heater core. Got everything ready to pull the dash. Except the 2 hex/allan screw/bolts in back of steering wheel (airbag equipped) are effing hell tight and are both stripped...I'm guessing someone else previously attempted this job, clue being the mould growing under the floor mat on the driver's side, and the heater hoses are bypassed in the engine bay.
    I'm at my wit's end trying to get these hex key bolt/screws whatever the f they are off... There's no clearance inside the wheel to put anything like a hacksaw inside to cut a groove in them and use a flat head screwdriver to get them off.
    Any ideas, tips or tricks?
    1994 Audi 80 V6 2.6E
  2. Re: Somebody kill me...now?!!!
    Jul 2008
    Lisburn
    15 Post(s)
    hammer in a slightly bigger torx bit? remove lower coloum and pull upper to clear steering wheel( not sure if this is possible, thinking of my ur set-up)?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
    0 2 0
  3. Re: Somebody kill me...now?!!!
    Mar 2016
    Australia
    Tried hammering in a slightly larger one when I was still trying to do this. Not enough clearance to get a decent swing of the hammer. And can't take the lower cowl off until after the wheel is off 😧
    Bought some thin saw blades last night. Gonna try slotting a groove in them and use a flat head screwdriver. Going to be completely screwed (pun intended) if I can't get them out. Can't get a drill in there either
    Sent from my SM-G900I using Tapatalk
  4. Re: Somebody kill me...now?!!!
    Mar 2007
    U-96
    Not sure about your working area/clearance is, but might it be possible to use a SHARP punch to to continue tapping the head of the bolt/screw to effect an anticlockwise loosening motion ?
    0 2 0
  5. Re: Somebody kill me...now?!!!
    Mar 2016
    Australia
    I'll try it. Man, I'm up for just about ANYTHING to get this done!
  6. Re: Somebody kill me...now?!!!
    Apr 2015
    Damascus, Syria
    Do you have a right-angle attachment for an ordinary electric drill? You can get "easy out" drill bits which thread themselves into the screw, but in an anti-clockwise direction. The more they enter the head of the screw, the tighter they get. Worth a try anyway, I have used them in the past successfully.
    Good Luck !!!!!
  7. Re: Somebody kill me...now?!!!
    Mar 2016
    Australia
    Quote Originally Posted by JMR1 View Post
    Good Luck !!!!!
    Good idea! Honestly, didn't know you could get right angled drill bits! I'll go to the hardware store after and see what I can find 😉
  8. Re: Somebody kill me...now?!!!
    May 2012
    Brighton
    Years ago I acquired a flexible drill/screw attachment. It allows you to drill/screw at various angles not just right angles. I have never used it but it may help with the reverse drilling and access.
    2011 3.0 TDi Quattro 245 - Tech pack - rear camera - Stronic - heated steering wheel - side lane assist - ambient light - speedlimit display -advanced key
    0 2 0
  9. Re: Somebody kill me...now?!!!
    Mar 2016
    Australia
    Quote Originally Posted by wildbeeste View Post
    Haven't been able to find anything like that around here, but there's a few things like it on eBay, as well as the 'easy out' bits. Bit strapped for cash atm, so I'm going to try some epoxy on a couple of old bolts that I had laying around. Tack them onto the offending bolts and hopefully (!!!) get the little buggers out! 🤔
    Bet ya that won't work either! 😓
  10. Re: Somebody kill me now?
    Mar 2016
    Australia
    Welp. That didn't work... 😧
    Now what???
    Seriously at my wit's end 😠
  1. My car is trying to kill me...
    By hshah in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-09-2015, 04:02 PM
  2. The wife's going to kill me next week............
    By stonedagain in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 13-06-2011, 12:35 PM
  3. Question Golf Plus Kill Switch
    By coolraj003 in forum Golf Plus
    Last Post: 27-10-2010, 08:07 PM
  4. Kill switches on motorbikes
    By Captain Answer in forum Chat - Completely Off Topic
    Last Post: 29-09-2008, 09:44 PM
  5. Does Speeding Kill?
    By Eshrules in forum Chat - Anything with wheels
    Last Post: 21-11-2007, 11:22 PM
