Thread: front electric Window regulator driver side
  1. front electric Window regulator driver side
    Dec 2014
    10 Post(s)
    Think my regulator has gone as had the crisp packet/eating a light bulb sounds emminating from the door.
    Originally I thought something (maybe twig) had somehow fallen in and was upsetting things so Took the interior trim off today hoping to see if I could work out what was going on. Switch activated the window fine and other door related electrics appear to be working so don't think I've got Apillar cable wear issues (yet).
    I fettled around a bit and used the switch to move the window And it went crazy spasming around and moving downwards overall despite me trying to coerce it upwards with my hand. Eventually it stuck 2/3rds up and the motor didn't even attempt to move it and trying to force it manually now seemed impossible. I thought I should probably go get on the forum at this point.
    hoping my curiosity has't caused any further damage and it's just the cable has eventually snagged on something as it's clear from info on here that scary noises from doors mean regulator issues.
    in case it helps others here's a load of posts that seem to offer something to do with this topic:
    B6 window regulator motor bolts
    Question Window alignment off after fitting new regulator
    A4 b6 cabby window regulator
    driver side window regulator
    Question Passenger side window regulator
    Question Drivers Window Shims
    Electric window issues, can i replace the cables without removing frame??
    Passenger windows Please help
    Please Help Crunching Window - repair
    Driver Window Problem
    VWVortex.com - DIY - Replacing the front door window regulator clips and/or door lock module
    Question Window regulator
    Please Help Window Regulator
    driver side window not opening
    The famous regulator "how to"
    DIY: B6 A4 - Window Regulator & Motor Replacement
    Right I'll be trying to follow that guide far enough tomorrow to confirm what's actually wrong and get my window closed!
    ian
  2. Re: front electric Window regulator driver side
    Jul 2007
    somerset
    8 Post(s)
    Did my passenger side a couple of years ago, would recommend using genuine part at £90 ish unless you love doing the job so much you want to do it all again in 6 months. Follow one of he guides and you should be ok, took me a couple of hours including coffee break, could probably do it in half that time now!
  3. Re: front electric Window regulator driver side
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Quote Originally Posted by rhencullen1989 View Post
    Ditto, ditto, ditto
  4. Re: front electric Window regulator driver side
    Dec 2014
    10 Post(s)
    Thanks I've gone with genuine it's coming into dealer on wed (£110) so hopefully sort it later in the week fingers crossed for some dry weather in Yorkshire... oh there goes a pig.
    Also attached a picture of the cross cables that got snarled round the motor EDIT can't seem to attach picture from iPad, prob not that useful anyway
    Ian
  5. Re: front electric Window regulator driver side
    Dec 2014
    10 Post(s)
    All done last Saturday, weather was helpful and didn't rain on me. Don't think I set any records time wise. Gave all the window runners a good dowsing of silicone spray so hopefully that'll keep everything running smooth for a bit.
    cheers
    ian
  1. Driver side electric window not working
    By vipergrm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2015, 09:14 PM
  2. Driver's side window not working - Not regulator issue
    By m8gic in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2015, 03:05 PM
  3. driver side window regulator
    By checkmate in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-11-2014, 10:50 AM
  4. Please Help Driver side electric window
    By faizulali in forum Audi A3 - Archive Topics
    Last Post: 20-01-2009, 04:48 PM
  5. driver side electric window
    By sumanb82 in forum Audi A3 - Archive Topics
    Last Post: 12-04-2007, 10:23 PM
