Thread: Passat 2.0 Diesel inlet manifold leaking oil on swirl flap actuator.
  1. Passat 2.0 Diesel inlet manifold leaking oil on swirl flap actuator.
    Oct 2016
    Bury St Edmunds
    My 2.0 diesel Passat B6 is leaking oil from the actuator pivot for the swirl flaps and it is expensive to replace does anyone have a repair solution for this or know if I can remove the swirl flaps and blank off the leak? Thanking you in advance.
  2. Re: Passat 2.0 Diesel inlet manifold leaking oil on swirl flap actuator.
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    No known repair kit for the flap rail in the plastic manifolds unfortunately. Some switch to the flapless metal manifold version (if you can find a used one). Removing the flap rail from the plastic manifold, making the vacuum actuator system redundant and coding it out to stop fault codes is messy.
    Mad Mitch
    1 1 0
  3. Re: Passat 2.0 Diesel inlet manifold leaking oil on swirl flap actuator.
    Oct 2016
    Bury St Edmunds
    Thanks for that Mitch, what would be your suggestion as the best cure for this problem other than spending around £500.00, assuming that there is another way around it. If I were to fit a metal manifold would anything need recoding? and do you know the part number of the metal manifold? Sorry for so many questions but just trying to decide what is the best thing to do.
  4. Re: Passat 2.0 Diesel inlet manifold leaking oil on swirl flap actuator.
    Jan 2012
    10 Post(s)
    87 Post(s)
    The plastic manifolds are on Darkside Development for around £360 including the gaskets I believe. Other than that there are a few metal manifolds out there and you would still have to make the vacuum actuation system needed for the flaps redundant.
    They also do this: http://www.darksidedevelopments.co.u...rsion-kit.html
    Read this on an Audi Forum (same engines and manifolds):
    http://www.audi-sport.net/xf/threads...nifold.238049/
    Mad Mitch
  1. Audi V6 TDi 2.7 & 3.0 Inlet Manifold, Swirl Flap Repair Kit.
    By tonyandkaty in forum 3.0TDi - Engine
    Last Post: 03-10-2015, 05:21 AM
  2. Swirl flap motor / actuator A6 2.7 tdi BPP
    By fmc51 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-07-2015, 03:10 PM
  3. A6 2.0 Tdi Inlet manifold actuator
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-01-2013, 04:10 AM
  4. Replies: 0
    Last Post: 22-09-2012, 11:37 PM
  5. Inlet manifold flap
    By davegilsenan in forum Audi A3 - Archive Topics
    Last Post: 02-03-2009, 03:48 PM
