Thread: Ignition Switch does not engage Starter
  1. Ignition Switch does not engage Starter
    I am considering purchasing a used 1997 Golf Jazz at a very nice price. 4 Cyl. 2.0 Gasoline engine. Automatic.
    The problem is that when the ignition key is turned nothing happens. The headlights go all the way out when the key is moved to the car starting position. Guy that owns it says that he used to drive it around every week or so, but one day it just happened that it wouldn't start. A new battery was just placed into the vehicle. Could the battery still be the problem? Or does anyone have any advice on what else it could be. I've been told that it's most likely not the starter. Any hints on what to check for first?
    Thank you.
    Ron
  2. Re: Ignition Switch does not engage Starter
    Co Durham
    It could be the starter inhibitor switch on your transmission. Try keeping the key turned to the start position & jiggle the A/T lever at the same time.
  3. Re: Ignition Switch does not engage Starter
    Just a follow up.
    I pulled the starter and had the starter bench tested at my local auto parts store. The starter would not work.
    I purchased a new starter and will install tomorrow to see if the problem is solved.
    Thanks for the response.
    Ron
  4. Re: Ignition Switch does not engage Starter
    One more question though....
    The new starter comes with a copper bushing with a warning that failure to install the bushing in the flywheel housing may result in damage to the starter and further non-starting condition.
    Does anyone know whether there is already a bushing inside the flywheel housing that has to be removed or would this be a first bushing being put in?
    Thanks for your assistance.
    Ron
  5. Re: Ignition Switch does not engage Starter
    the copper bush your talking about may not be fitted or if it is, it may be worn! make sure you fit the new one supplied, if you dont it will ruin your new starter and make a horrible noise when turning over the engine! good luck!
  1. Removing Ignition Switch 1990 Audi 90
    By HarrytheHorse in forum 80 - 90
    Last Post: 31-08-2007, 10:07 PM
  2. MK3 Ignition Switch trouble?
    By milescook in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2007, 04:18 PM
  3. polo 98 ignition switch removal & fitting
    By Hiral in forum Polo - Derby - Lupo - Fox
    Last Post: 22-08-2007, 09:27 PM
  4. How do you engage the starter after the alarm kills it.
    By justpanicn in forum Archive posts
    Last Post: 24-07-2007, 07:39 PM
  5. 94' Passat 1.9 TD - Dodgy Ignition Switch
    By paularcher in forum Passat - Archive Topics
    Last Post: 31-12-2006, 06:25 PM
