Thread: clutch
  1. clutch
    Sep 2016
    leeds
    Hi, recently i have had some problems trying to select 1st and reverse gear on my 2.0 tid 140, 2006, it only happens every now and then, and if i select 3rd gear first, both 1st and reverse go straight in with no problem, then today when i was sat in traffic with the car in 1st i noticed if i let the brake off the car started moving forwards, not fast, just as if the clutch pedal was raised a little, and ideas ???
  2. Re: clutch
    Pembrokeshire
    22 Post(s)
    slave cylinder leaking. whats the fluid level doing, anything dripping from the bottom of the engine / gearbox ?
  3. Re: clutch
    Sep 2016
    leeds
    It is dry as a bone underneath, although there is the plastic engine cover under the engine, but there is never any fluid under the car, I was thinking maybe air in system, it has had new front discs and pads before I bought it.
  4. Re: clutch
    Your clutch is not disengaging properly which is stopping it select gears, is the biting point near the floor ? Could be the master cylinder or more likely slave cylinder, I would get it bled and see if that helps. Is it better if you pump the clutch pedal a few times ? I would get this fixed as it will not be doing your gearbox syncromesh much good. Possibly a warped clutch plate or faulty pressure plate has the clutch been badly over heated recently ? cheers Ben
  5. Re: clutch
    Sep 2016
    leeds
    Quote Originally Posted by MissSpentYouth View Post
    cheers ben, yes i have had the clutch bled and still no different, it is very random when it does it, i have had the car to a gearbox/clutch specialist as well as my own mechanic and they are both saying flywheel. also not sure if the clutch has been overheated as i have only had the car 4 weeks.
  1. Replies: 8
    Last Post: 21-10-2016, 06:38 PM
  2. Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    By uncleron in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2013, 08:37 PM
  3. Replies: 5
    Last Post: 08-04-2013, 09:23 PM
  4. Please Help Replaced flywheel and clutch kit......but still makes that clunk noise from the clutch :(
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-06-2011, 05:04 PM
  5. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
