Thread: Trying to find full info on retrofitting !!OEM!! LED taillights from HALO taillights
  1. Unhappy Trying to find full info on retrofitting !!OEM!! LED taillights from HALO taillights
    Oct 2016
    Aberdeen
    I just got a good deal on OEM headlights and tail lights and waiting to get them. Until then, Im trying to gather a full set of instructions on how to fit the tail lights, from what i researched until now, I get that the coding of the BCM module will represent a bit of trouble.
    Is there anyone here that can provide a full set of instructions (as detailed as possible) for replacing the stock, HALO taillights with OEM LED ones?
    Many thanks!
    EDIT: Unfortunatelly, this thread: 2009 Audi A4 B8 Saloon LED Taillights Retrofit - Hopefully definitive guide soon hasn't provided much info or the info is split in many many attempts to get to a result with no obvious outcome.
  2. Re: Trying to find full info on retrofitting !!OEM!! LED taillights from HALO taillights
    Jun 2008
    7 Post(s)
    Only way I know is to contact davidB8 as you know coding has to be done and apart from buying the correct model from Audi and getting them to code it into your system I can not see any other way as the BCM in question if coded wrong will totally F--k up things for you and you will be without a car that you can start.
  3. Re: Trying to find full info on retrofitting !!OEM!! LED taillights from HALO taillights
    Oct 2012
    Estonia
    64 Post(s)
    Davidb8 left long time ago to Singapore and he is not helping even guys who donated and covered his a...long time in forums. Btw, even Davids coding is play with bulberror, so you will not have like factory setup, same with kufatec, so just make a harness, there is plenty threads and coding options available...No need to be afraid f... up the module!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  1. Replies: 23
    Last Post: 04-05-2017, 09:11 AM
  2. Please Help Retrofit 2010 8p taillights to 2006 A3
    By v11kal in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-01-2011, 09:39 PM
  3. Do these look like the A8 taillights?
    By boooo4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-10-2010, 10:21 PM
  4. Anyone removed rear taillights?
    By gebbel in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-03-2010, 07:06 PM
  5. Hella LED taillights help!
    By jasonk in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2008, 10:03 PM
