Thread: [golf 4 1.6 sr akl] Rough idle and engine dies sometime
  1. [golf 4 1.6 sr akl] Rough idle and engine dies sometime
    Sep 2016
    Peterborough, UK
    Hello guys.
    I have a problem with my Golf 4, 1.6 SR, automatic, engine code AKL. The idle is really bad, the rpm's are going down to nearly 400 rpm, then goes back up, then down again, car sounds like misfires when idling, the engine sometime dies at a red light stop because I don't have clutch to press. I have replaced the spark plugs, spark plug leads, ignition coil, temp sensor, maf sensor, intake air sensor, throttle body but my problem its still there. Does anyone know what else I can do?
  2. [golf 4 1.6 sr akl] Rough idle and engine dies sometime
    Jun 2016
    Glasgow
    Have you checked for air leaks/looked at fuel?
  3. Re: [golf 4 1.6 sr akl] Rough idle and engine dies sometime
    7 Post(s)
    Have you electronically aligned the throttle body ?
  4. Re: [golf 4 1.6 sr akl] Rough idle and engine dies sometime
    Mar 2019
    Ipswich
    Spent hours on the forums with AKL rough idle and there does not seem to be a definitive answer !!??!! So still really struggling
  1. Please Help Rough idle when engine is warm
    By d1s in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-08-2015, 02:12 PM
  2. Vw Golf AKL engine - 1.6 sr 8v SE - New problem with Idle and Vcds
    By bartas in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2014, 09:28 PM
  3. Please Help Engine starts but does not idle and dies
    By pinki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2013, 08:14 PM
  4. rough idle once engine is warm
    By liamthecoder in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2012, 11:42 PM
  5. Please Help golf 1.4l engine dies
    By serpent1 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-10-2010, 07:00 PM
