Thread: Q5 EGT sensors
  1. Q5 EGT sensors
    Sep 2016
    GB
    I'm trying to fix some issues for a friend on their 2011 2.0 TDI Q5. Basically when I scanned it with VCDS I got a load of errors relating to the DPF, the main one was the differential pressure sensor which I have now replaced and the error cleared. The dpf reads 15g soot measured and 18g calculated. The remaining errors are relating to exhaust gas temperature sensors and I was reluctant to force a regeneration without them working.
    Basically EGT bank 1 sensor 4 reads -100.0C, sensor 1 reads 20.0C, sensor 2 reads -0.0C and sensor 3 reads 108C at idle. Has anyone come across this before? Is it likely that all 4 sensors need replacing or is something else likely to be causing it? E.g. a Fuse etc?
    Any help appreciated.
    Sent from my SM-G935F using Tapatalk
  2. Re: Q5 EGT sensors
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by BorgRM View Post
    Take the readings again on a cold engine not started. They should all be fairly the same which will be about ambient temperature. Any major anomoly and that's your faulty sensor. Or you may even have 2.
  1. Help: EGT sensor
    By Zedwan in forum VCDS - Help Requests
    Last Post: 08-06-2014, 09:42 PM
  2. Replies: 8
    Last Post: 24-04-2014, 07:04 AM
  3. Question Chnged EGT 1 + 2 STILL LUMPY
    By the lemster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2012, 11:42 AM
  4. 2.7T EGT Sensor Fix
    By vwrich85 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-07-2012, 08:58 PM
  5. Please Help Egt sensor
    By Silver_AudiS3 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-11-2010, 11:00 AM
