Thread: How to code/setup new actuator?
  1. How to code/setup new actuator?
    Sep 2015
    Lincoln
    Does anyone know how to code in/setup a new vacuum type actuator for the 2.0tdi cbab engine?
    I have vcds so wondering if anyone knows the correct procedure. Thanks
    Sent from my LG-D855 using Tapatalk
  2. Re: How to code/setup new actuator?
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Crasher is probably your man. He runs his own shop and most certainly knows how.
    Mad Mitch
  3. Re: How to code/setup new actuator?
    Sep 2015
    Lincoln
    Thanks for your reply but I had a look last nights and thought it looks too tough for me! £112 for a local Indy to do it, with me supplying the part, reluctantly that will be the route I take!
  4. Re: How to code/setup new actuator?
    1840 Post(s)
    £112 is a bargain, I would charge 3 hours so £199, it's a painful job to set up precisely.
  5. Re: How to code/setup new actuator?
    Sep 2015
    Lincoln
    That's what I thought, looks fiddly with not much room or visibility for adjustment. Snapped there hand off!
  6. Re: How to code/setup new actuator?
    Sep 2015
    Lincoln
    All done in the end, new actuator cured the fault, all fitted and set up in vcds for £80, bargain!
    Sent from my SM-G935F using Tapatalk
  1. fault code help Intake Manifold Flap and Throttle Actuator Control System
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-04-2016, 06:05 PM
  2. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  3. VCDS code 17042 - Engine Actuator Supply Voltage A: Too Low
    By olly811 in forum VCDS - Help Requests
    Last Post: 27-01-2015, 08:41 PM
  4. Replies: 1
    Last Post: 05-01-2013, 08:34 PM
  5. error code 17965 on 110 tdi, need a new actuator?
    By tezray in forum Archive posts
    Last Post: 26-10-2007, 04:56 PM
