Thread: Niggly bits on my wifes Leon 170 BMN
  1. Niggly bits on my wifes Leon 170 BMN
    Sep 2016
    truro England
    Hi guys I have signed up for the purpose of hoping to get some advice really.
    My wife bought her dream car last year, a seat leon 170 FR 2007 BMN engine and now its starting to develop faults that are really annoying. The car drives great with the exception of being stuck in traffic. if it idles for a period of time, it starts smoking white and and idles lumpy, and the smell is disgusting. I have checked coolant, oil, compressions and all are great, not loosing a drop of anything.
    the other day we were driving and the glow light flashed and it went in to limp mode as well, now I don't think the two issues are connected but I am studying LVL 3 light vehicle repair at college as a mature student and had a chance to use our diagnosis tool. the codes it threw up were
    06469 Control module 1 for cooling fan: output short circuit P1945 open circuit short
    00551 Throttle pedal position sensor G79 signal too low P0227 short with ground
    05683 Accelerator position sensor 2 G185 signal too low P1633 short with ground
    has anybody encountered these faults before???
    Any help is hugely appreciated.
  2. Re: Niggly bits on my wifes Leon 170 BMN
    Jul 2007
    glasgow
    35 Post(s)
    have you checked your wiring loom for these shorts ?
    have you checked STORED & PENDING codes ?
    is it a diesel or petrol car ?
  3. Re: Niggly bits on my wifes Leon 170 BMN
    Sep 2016
    truro England
    literally just plugged it in this morning, will be disconnecting the throttle pedal later and checking voltages. its more the cooling module that has me, would it be a reason for it smoking at all?
    and these were after I had cleared the codes last week, so definitely the problems.
    it is a diesel 170 FR. Thanks
  4. Re: Niggly bits on my wifes Leon 170 BMN
    Jul 2007
    glasgow
    35 Post(s)
    has your car got a dpf fitted and its coming on giving you the smoke etc ?
    flashing glow plug light can be accelerator position switch, brake pedal switch or clutch pedal switch .............. yours is saying accelerator
    #the coolant is possibly the wiring to the sensor in the radiator or the sensor itself. Be careful changing them as the brass face can be easily damaged
    the other coolant temp sender unit is traditionally at the thermostat , this sends signal to dash & ecu ................. if this fails it usually tells car its cold & gives extra diesel to engine, a default setting
    smoking white is usually head gasket failure or unburnt diesel ............. I am guessing its your dpf
  1. Please Help Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    By jwalman in forum Golf MK5 - 2004 - 2009
    Last Post: 10-05-2015, 12:25 PM
  2. Golf Mk5 TDi 170 BMN continues accelerating after lifting off!
    By nick8428 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-11-2014, 11:36 PM
  3. Question A3 2008 Quattro 2.0 170 (BMN eng code) - intermittent poor starting.
    By audikid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-11-2014, 03:47 PM
  4. 2.0tdi 170 bhp bmn engine code oil capacity
    By sbt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-12-2012, 12:06 PM
  5. golf 170 bmn into passat bmr?
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2010, 12:55 PM
