Thread: rear supension creak Allroad
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: rear supension creak Allroad
    Aug 2019
    Surrey, UK
    Also just purchased a 2016 allroad with 40k+ miles, same issue on Allroad setting and occasionally on other settings. What do I need to do to drop the bump stops? Do I remove the wheel and pull the stop out of the mount? Also found this TSB, which advises using "Tyre Mounting Paste" to fit bump stops" https://static.nhtsa.gov/odi/tsbs/20...66028-2280.pdf Tyre paste would I believe dry out and not provide lubrication... I would appreciate recommendations on what to "lubricate" the bump stop with? I would have guessed Silicon Grease as used by plumbers and electricians??
  2. Re: rear supension creak Allroad
    Jan 2018
    Cheshire UK
    I have recently had to do this to my recently purchased 2016 Biturbo Allroad with 40k on it.
    Really easy to do, jack up, remove wheel (I did both sides, even though it was only the N/S squeaking), use a medium flat blade screwdriver to “unseat” the bump stop and grasp hard and twist/pull down. It will eventually come out of its housing, don’t butcher it and tear the rubber material. Use a big flat blade screwdriver, or similar to scrape out the worst of the whitish aluminium corrosion, I then cleaned up as best as I could with an abrasive pad, I suppose you could use a pot scourer type thing as well.
    I then coated the outside of the bump stop with red rubber grease (which won’t attack the rubber over time), you can buy little tubs cheaply on a certain auction website. Make doubly sure the bump stop is fully inserted all the way back into the housing when refitting.
    I was quite sceptical that this fix wouldn’t work, but it does, lovely and silent now. All credit to whoever discovered this fix.
  3. Re: rear supension creak Allroad
    Aug 2019
    Surrey, UK
    Thanks to all - annoying creaking now gone on Allroad and occasionally on other ride heights. Pulling or twisting I thought I would destroy the bump stop!.. I gently pushed a medium flat screwdriver up between the rubber and the mounting each side and then levered the bump stop down about 3 or 4mm, it then pulled out easily. I cleaned up and lubricated with red grease (Rubberlube), which I also rubbed around inside the aluminium cup. The bump stop pushed easily into place and has stayed put.
  4. Re: rear supension creak Allroad
    Aug 2020
    Bollington, UK
    Thanks all for contributing towards this thread. I’ve had the same issue which was easily resolved as described.30F6DE61-97DE-4548-A267-64DA28047E8E.jpg
  5. Re: rear supension creak Allroad
    Sep 2020
    Sweden
    Thank you very much for this thread! This was the exact same issue I had and that is now resolved with just 5 minutes of my own labour thanks to this thread!!! So happy! Greetings from Sweden
  6. Re: rear supension creak Allroad
    Aug 2023
    Wolverhampton
    Fantastic find. This was exactly my problem with rear near side suspension. White salt like deposits at top of bump stop. All cleaned out and lubed up with silicone spray. Totally cured problem. Silent driving from now. Just to add though, the bump stops are looking very dry and starting to crack too so I intend to replace these at some point soon. Thanks again.
  1. Question supension advice
    By mihaib6 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2015, 05:42 PM
  2. Avant Load cover nosiy as hell also rear bootlid creak !!
    By rs4al in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-09-2011, 11:37 AM
  3. Avant Load cover noisy as hell also rear bootlid creak !!
    Last Post: 20-09-2011, 05:28 PM
  4. Question rear supension noice problem
    By dorosth in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-02-2010, 09:36 PM
  5. A4 supension upgrade or not?
    By SRA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-05-2008, 11:51 AM
