Thread: hand held diagnosic scanner
  1. hand held diagnosic scanner
    Jul 2016
    hi all , i have an A4 B7 2.o tdi and am looking to buy a hand held scanner code reader . There is loads on the market for anything from £15 upwards , what is the best on to go for value wise and ability to read fault codes with out spending a small fortune .
  2. Re: hand held diagnosic scanner
    Jul 2008
    Lisburn
    15 Post(s)
    I had a vag405 read every thing but faults on 2 different cars. I am now looking at the vs405 going to get it tomorrow.
  3. Re: hand held diagnosic scanner
    Jul 2016
    so you saying it wont read fault codes ? was it any good for resetting air con issues
  4. Re: hand held diagnosic scanner
    Jul 2008
    Lisburn
    15 Post(s)
    my car at the time didnt have Aircon, 99 passat, I had an airbag light on and the reader would read the module info and reset any codes, but locked up when it came to read the code... did the same with a missfire code on an 03 TT
    I bought it from chinoeuk2010 on ebay and they said return it for a refund, i did and havent heard anything since...
  5. Re: hand held diagnosic scanner
    Jul 2016
    ok thanks for that , let me know how you get on with your new on , hopefully better !
  6. Re: hand held diagnosic scanner
    Jul 2008
    Lisburn
    15 Post(s)
    Got the scanner yesterday.
    its ok, its a general scanner for all VAG models, you pick yes for vag and then you can read a list of 15 - 20 modules.
    Aux Heat is one but i got a link error - ie not in my car, most did work and read.
    I have 2 issues - swirl flaps and intermittent parking sensor.
    I got t 4120 fault code for the swirl flaps of which i had to manually search the ross tech site to find out what it meant, and i wasn't able to find anything with the parking sensors.
    I am maybe being unfair as i have used the BMW (can i say that here) c110, with this one you select your model ie 5 series then chassis, E60 for example, then you have a list of all, possible available modules.
    This also has the same draw back as the vs450 of having to access them individually to scan.
    but BM dont have VAG COM...
    this is not me and i haven't watched it fully but seems to review the scanner:- Vgate Scan VS450 - YouTube
  1. Question LEFT hand drive TO right hand drive headlight beam benders
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2014, 06:02 PM
  2. Would getting my own hand held scanner tool be worth it?
    By Grandad Dave in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2011, 01:11 AM
  3. hand held diag tool
    By chrishgd in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 16-03-2011, 01:22 AM
  4. Question Vagcom Scanner?
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-02-2010, 08:52 PM
  5. T45e Hand scanner for 1998 B5
    By andysuth in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 29-09-2009, 09:02 PM
