Thread: ABS Module Will Not Hold Its Coding
  1. ABS Module Will Not Hold Its Coding
    Aug 2016
    leicester
    I have bought a used abs module for my car and needed to re code it, the abs units have exactly the same numbers and its a Bosch 5.7, when I try to recode it in VCDS the code is accepted and showing up ok, but when I turn off the ignition and back on again the code has gone back to 00000 again, any ideas please, I followed the Ross Tech video on this, everything was ok before the abs was unplugged
  2. Re: ABS Module Will Not Hold Its Coding
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I wonder if you need to enter the same code into the central electrics unit also?? Never done this but either the ABS unit is faulty or some other coding to be done?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: ABS Module Will Not Hold Its Coding
    Aug 2016
    leicester
    I did it exactly as per Ross Tech instructions, it didn't say anything else about recoding central electrics, but I will look into it thanks.
  1. 2003 A4 3.0 Quattro CODING FOR ABS MODULE assistance please if possible?
    By Unlucky A4 3.0 in forum VCDS - Help Requests
    Last Post: 18-12-2019, 08:37 AM
  2. Replies: 1
    Last Post: 22-01-2014, 10:59 PM
  3. ABS Module: electrically connecting another module while not installed in the car?
    By dansansome in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2014, 04:17 PM
  4. coding replacement ABS module Audi B5
    By DeeJames in forum VCDS - Help Requests
    Last Post: 19-06-2013, 04:14 PM
  5. '99 2.8 ABS module symptoms? no rev counter, ABS and oil pressure warning.
    By bubbster in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
