Thread: Another Fault code.. VAG-COM - ENGINE - Can you help?
  1. Exclamation Another Fault code.. VAG-COM - ENGINE - Can you help?
    Dec 2006
    I have been getting the below code also for some time...
    have had the below fault log many times over the last year or too..
    17698 - - Coolant Temp Sensor at Radiator Outlet (GB3) Singal too Small.
    P1290 - 002 - Lower limit Exceeded
    I think its a sensor mounted at the front right of the car under the rad..
    Does anyone know the exact location and part number for this sensor..??
    Rick
  2. Re: Another Fault code.. VAG-COM - ENGINE - Can you help?
    May 2007
    knee deep in clunge
    14 Post(s)
    Its on the lower radiator pipe,sorry dont know the part number
  3. Re: Another Fault code.. VAG-COM - ENGINE - Can you help?
    Dec 2006
    ok.. is there a common name to call it if i nip into Audi Trade Parts.. or would i be best just giving the fault code..??
    Rick
  4. Re: Another Fault code.. VAG-COM - ENGINE - Can you help?
    May 2007
    knee deep in clunge
    14 Post(s)
    G83 coolant sender.They will try to supply you with the coolant that lives at the back of the cylinder head and that is called G62
  5. Re: Another Fault code.. VAG-COM - ENGINE - Can you help?
    Dec 2006
    Cheers mate..
    Rick
  6. Re: Another Fault code.. VAG-COM - ENGINE - Can you help?
    Dec 2006
    Quote Originally Posted by a8 tech View Post
    Cheers.
    Going to look into getting this sorted this weekend..
    G83 coolant sender. - Once i get a part number i will post to save time in the future!
    Rick
  7. Re: Another Fault code.. VAG-COM - ENGINE - Can you help?
    Nov 2008
    Quote Originally Posted by RickT View Post
    Cheers.
    Rick
    Did you resolve this issue mate? Mine has the same error code...
  1. Engine starting problems Vag code fault codes listed
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 10:06 PM
  2. Fault code
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 08:41 PM
  3. VAGCOM Fault code
    By fatgolfer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-01-2007, 12:46 PM
