Thread: A3 won't start fault code 01176 - key - 008 - implausible signal - intermittent
  1. Angry A3 won't start fault code 01176 - key - 008 - implausible signal - intermittent
    Jun 2016
    Dublin
    Hey,
    My car decided today it wasn't going start, used the car all day yesterday and parked it up last night and had no issues. Today it wouldn't start. It turns over but won't start. Ran the vagcom and the only fault coming up is ( 01176 - key - 008 - implausible signal - intermittent), There isn't much on online about it only that it might be the immobiliser reader coil. I have two keys and both won't start the car, I changed the battery in both keys just incase. I also disconnected the battery on the car for a few mins to see if that would do anything. I know reprogramming the key to the immobiliser could help but I don't have the security code that allows me to do that. Is there any anything else I could check or try to do to fix the problem.
    Thanks in advance.
  2. Re: A3 won't start fault code 01176 - key - 008 - implausible signal - intermittent
    Nov 2008
    Cramlington,Northumberland
    10 Post(s)
    You could strip covers on steering lock and check reader coil and wiring for defects
    Alan.
    APR ST1
  3. Re: A3 won't start fault code 01176 - key - 008 - implausible signal - intermittent
    Jun 2016
    Dublin
    Quote Originally Posted by Alan02 View Post
    hey, just striped them off there now. all looks good, is it a big job to switch the reader coil. Do you know where the cable from the reader coil go's to? Also now getting a fault code for the fuel pump relay, which I think is relay 167 under the bonnet. I don't know if I'm getting that fault because the voltage from the battery probably dropped after the attempts to start it. I cleared the fault for the key and it hasn't reappeared, Am i right in saying it should reappear if there is a problem with the immobiliser.
    When I test the fuel pump relay J17 in vagcom what should happen? would I just hear the relay click or would the fuel pump start? When i run the test I can't see or hear anything happening!
  1. 02000 - Switch Position, 008 - Implausible Signal
    By netmonky in forum VCDS - General Questions
    Last Post: 27-08-2018, 02:34 PM
  2. 2.5TDi won't run properly - Fault Code 00550 - Start of Injection Regulation -
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-06-2015, 09:18 PM
  3. Fault code 18043/P1635-008
    By rrremix in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2012, 12:50 PM
  4. 01176 key signal too low
    By pops20vq in forum Golf MK4 - 1999 - 2004
    Last Post: 04-08-2008, 07:22 PM
  5. Error Code- Potentiometer for EGR?? Implausible signal ??
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-01-2008, 09:57 PM
