Thread: Adaptive Air Suspension
  1. Adaptive Air Suspension
    Aug 2016
    coventry
    10 Post(s)
    It appears I get confused easily.
    Our Q7 has the AAS which comes with a button in the boot that allows the boot to be lowered to get things in and our easier (for us it is good for the dogs to be able to jump in the boot). Sometimes this button works, sometimes it does not, I can't seem to find a common reason for either.
    I noticed it doesn't work at all in Off-Road Mode. Sometimes it needs the ignition on, sometimes it doesn't. Sometimes it won't work with the doors open, sometimes it does.
    Does anyone know what the criteria is? Even better, can it be coded to work all the time?
  2. Re: Adaptive Air Suspension
    Jul 2010
    uk
    183 Post(s)
    Hi Mica, sounds about right...what I've read is that no doors should be open to get it to work...well apart from the boot obviously.
    Also doesn't need ignition on etc
    I've also found sometimes on pressing the button it doesn't lower and sometimes it does - I think you need to press and hold for a second and then it lowers no issues.
    Re off-road mode - haven't tried it in that mode so can't comment on that bit
  3. Re: Adaptive Air Suspension
    Apr 2016
    Stansted
    169 Post(s)
    I think whether you need the ignition on depends on whether there is pressure in the system (my limited understanding!)
    If you've just stopped I find it always works but is hit and miss if the car has been parked a while.
    Former Q7 owner
  4. Re: Adaptive Air Suspension
    Mar 2010
    37 Post(s)
    228 Post(s)
    Yup, Nemo is right on the doors... I admit, sometimes its like that on mine. I just let go of button and press again then it works!?!
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  5. Adaptive Air Suspension
    Jul 2010
    uk
    183 Post(s)
    So yesterday I picked up a nail in my tyre but luckily enough a repair was all that was needed and the good guys (well I hope they were good) at Kwik Fit sorted its
    Anyway afterwards I was just playing with the air suspension and learnt something new but I'm sure it was just me . Put the car in off-road and decided to step out of the car to watch it, never realised the car actually moves a little as it raises / lowers. Did freak me out for a second as I thought the handbrake/parking brake was off
    And yes this is how dirty the car will be next week...
  6. Re: Adaptive Air Suspension
    Mar 2016
    Ipswich
    72 Post(s)
    I don't know why it moves a little must be to do with the camber or angle of the shocks
    if you sit with foot hard on the foot pedel then say change setting to off road and wait till car is fully raised then take ya foot off the breaks the car jilts to allow the wheel footprint to move if you do the same with just the hand break on it don't do this as only the back wheels are locked allowing the front wheels to move
    like above for raise lower of boot some times have to press button a second time
    ignition don't have to be switch on to lower the boot as long as all door are shut tail gate is open
    the only time you need ignition on is the adjust the air suspension from inside the car i.e. Going from dynamic to off road or auto etc
    just lowering the boot no ignition needed
    M
  1. A7 Adaptive air suspension
    By jbanfie in forum A7 - S7
    Last Post: 20-12-2015, 10:08 PM
  2. A8 adaptive air suspension
    By stuart21 in forum A8 - S8 - V8
    Last Post: 06-10-2013, 04:27 PM
  3. Adaptive air suspension/parking module
    By Chipsteruk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2013, 02:34 PM
  4. Bang goes the Adaptive Air Suspension
    By pld118 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 07-08-2012, 09:04 PM
  5. adaptive air suspension - opinions
    By jcb in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-06-2008, 07:31 AM
