Thread: Upgrading factory 'Audi Audio' DIY
Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 148
  1. Re: Upgrading factory 'Audi Audio' DIY
    #21
    Jun 2009
    Lowestoft, England
    10 Post(s)
    Quote Originally Posted by wolek76 View Post
    There you go Pitch
    h**p://www.ebay.co.uk/itm/351685548633
    Admittedly, I went for the looks and it didn't work out quite right. But the sound is GOOD.
    great stuff and Ta.
    HIS - XC90 D5 R Design (sorry, had to be done)
    TOY - 2001 Westfield 2.1 SEW,172bhp SOLD TO MY BROTHER, I needed a PANERAI.
    HERS - 'R' New 7spd DSG and 310 rampant ones. 4.2 off the mark will do nicely
  2. Re: Upgrading factory 'Audi Audio' DIY
    #22
    Nov 2008
    Quote Originally Posted by nbedford View Post
    Interesting project, could you just fit the BOSE subwoofer - ​4M0035621A(there a few on ebay for around 120 EUR) or would you need the BOSE amp to drive it?
    I like nbedford's idea if that would work? Can you replace any of the speakers with Bose without using the Bose Amp I wonder???
    2012 Audi A7 SE, Midnight Blue, MMI Plus with touch, Adaptive Cruise Control, Lane Assist, Blind Spot Monitoring, Head Up Display, Audi Pre-Sense, 2wd 8 speed.
  3. Re: Upgrading factory 'Audi Audio' DIY
    #23
    Jun 2011
    london, uk
    7 Post(s)
    Quote Originally Posted by Skippy73 View Post
    I did think about that admitedly. But it's much more complicated sadly.
    Here is some proof...
    That's bose speaker and a woofer box that goes with it into the door
    And that's what I found behind my door trim:
    So. To reiterate.... As I always say to my customers : "everything is possible" but it is just the matter of time money and effort.
    In my case I'm just going to live with it. :/ just too much hassle to swap it all
  4. Re: Upgrading factory 'Audi Audio' DIY
    #24
    Feb 2013
    Manchester uk
    Thanks for posting.
    I too went for the stock setup. I looked at the sub and have toyed with the idea of changing the driver, either better quality 6 inch or shallow mount 8 inch. Not sure if the volume of the box is right for an 8 inch.
    Was wondering if it needed a separate amp to get anything decent from it, the stock one is ok if you crank the volume up, so thought a better sub would need a bit more to drive it. How much difference has it made on yours just swapping tye driver?
    i too am thinking about an upgrade to all the speakers.
  5. Re: Upgrading factory 'Audi Audio' DIY
    #25
    Feb 2013
    Manchester uk
    Also does anyone know where the stock amp is? The bose I think is in the trunk, but I cannot track down the standard setup amp.
  6. Re: Upgrading factory 'Audi Audio' DIY
    #26
    Feb 2013
    Manchester uk
    Thanks for posting.
  7. Re: Upgrading factory 'Audi Audio' DIY
    #27
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    The standard amp is built in the infotainment system, which houses the card reader (J794 Control unit 1 for information electronics) as well. The speakers are connected to this unit on the T8z connector (brown) at the back of the unit. This unit drives the front and left speakers. The treble and bass (door) speakers are connected parallel. Looks like the treble high pass filter is just a capacitor. Also this unit drives the center speaker and subwoofer as well (T8i connector black).
  8. Re: Upgrading factory 'Audi Audio' DIY
    #28
    Feb 2013
    Manchester uk
    Wolek76
    do you know what diameter that door speaker is. It appears the flange is all part of the speaker?
    thanks
  9. Re: Upgrading factory 'Audi Audio' DIY
    #29
    Jun 2011
    london, uk
    7 Post(s)
    Quote Originally Posted by Jwjaudi View Post
    Wolek76
    thanks
    Hi.
    Here is the diameter in the foto
    Also, it is not your standard speaker! I am not sure what you mean by the flange but this particular speaker in the door comes welded into its housing! And only the housing gets mounted onto the door. A very custom way of doing things.
    I bet it's the same for the back door too.
    If you need I have a front/back door dismounting manual. All of the trim is held by three screws :O
  10. Re: Upgrading factory 'Audi Audio' DIY
    #30
    Feb 2013
    Manchester uk
    Thanks for the size. Manual for trim removal would be great.
  1. Please Help Audi A3 s3 Bose Audio System - Audio Leads/Wires
    By mekkararamesh in forum In Car Entertainment
    Last Post: 25-09-2016, 07:50 PM
  2. Replies: 5
    Last Post: 21-03-2011, 09:48 PM
  3. Question upgrading audio
    By deckymcd80 in forum Bora - 1998 - 2005
    Last Post: 31-07-2009, 10:34 AM
  4. Upgrading the existing factory fit alarm
    By aussie_surfer74 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-07-2009, 11:46 PM
  5. A3 Audio Upgrading
    By flex786 in forum Audi A3 - Archive Topics
    Last Post: 23-08-2008, 07:03 PM
