Thread: Errors after fitting LED bulbs
Results 1 to 10 of 12
  1. Angry Errors after fitting LED bulbs
    Jun 2008
    Hi all,
    I bought some of the LED replacement bulbs from ebay (Chinese, supposedly error free ones) and fitted them at the weekend, whilst doing the door light the LED bulb arc'd on the contacts causing the fuse to blow. eventually I fitted them all and they were fine and I replaced the fuse. When I went to use the car in the morning I had loads of errors on the dash (adaptive lighting, ESC, tyre inflation, steering).
    I took it to my local audi specialist and they connected it up and cleared the errors but they remained afterwards. I now have slight heavy steering and still ESC error and adaptive lighting error and warning triangle. I have since refitted the old bulbs just in case, but have the lights/fuse caused an error, or could there of already been an error.
    Its going back in the garage Monday for the first MOT, and they will check again.
    is there anything I could try in the meantime.
  2. Re: Errors after fitting LED bulbs
    Mar 2008
    11 Post(s)
    Quote Originally Posted by longmanjon View Post
    Hi all,
    I took it to my local audi specialist and they connected it up and cleared the errors but they remained afterwards. I now have slight heavy steering and still ESC error and adaptive lighting error and warning triangle. I have since replaced the old bulbs just in case, but have the lights/fuse caused an error, or could there of already been an error.
    Have you checked the fuse that handles the bits that don't work/error?
    Might be that further fuses went when the first one went
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  3. Re: Errors after fitting LED bulbs
    Jun 2008
    I checked a few last night, but will have to do a sweep of them all just in case
  4. Re: Errors after fitting LED bulbs
    Apr 2009
    Surrey
    174 Post(s)
    Don't forget there are fuses all over the place (boot area side and under the floor) and not just on the end of the dash
  5. Re: Errors after fitting LED bulbs
    Jun 2008
    i checked all the fuses in the boot and ends of the dash and no other fuses have gone, but still getting adaptive lights, esc, and steering errors. frustrating for sure. I did notice though that the fuel cap cover is not locking, so not sure if this could be the cause for any of them?
  6. Re: Errors after fitting LED bulbs
    Have you tried ditching the cheap chinese bulbs and refitting the OEM ones to see if that cures the faults?
    0 2 0
  7. Re: Errors after fitting LED bulbs
    Jun 2008
    yes I had done that once all the issues arose, but they are still there.
  8. Re: Errors after fitting LED bulbs
    Aug 2016
    Veldegem - Belgium
    Have you checked the fuses under the steering wheel? you need to remove the plastic cover and then you wil see some fuses underneath the steering wheel. Also the one for indoor lightning.
  9. Re: Errors after fitting LED bulbs
    Jun 2008
    Yes just checked the ones under the steering column all fine. How do I know if I have adaptive lighting
  10. Re: Errors after fitting LED bulbs
    Aug 2016
    Veldegem - Belgium
    Do the lights turn when you are turning with the car? if yes, you have adaptive headlights
  1. Question LED Bulbs in non-LED front running Lights
    By John140 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-11-2016, 01:30 AM
  2. Fitting LED numberplate bulbs without error
    By Coxy789 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-09-2013, 06:43 PM
  3. Anyone fitted Led Indicator Bulbs Error Free Bulbs?
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-10-2012, 11:11 PM
  4. Fitting LED sidelight bulbs
    By n1cka8 in forum A8 - S8 - V8
    Last Post: 20-04-2011, 12:29 AM
  5. LED number plate bulbs finally fitted with pics! NO ERRORs also got my side lights!
    By Killer passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-12-2009, 10:47 AM
