Thread: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
  1. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    Pembrokeshire
    22 Post(s)
    A local powdercoater would have made your life much easier, awesome work.....
    just done my 80, rear axle, shock towers, front subframe, axle mounts, all for 120 notes.
  2. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    7 Post(s)
    Thought it was a bit too rusty but then you mentioned you live on Skye...
    Top, top work.
    1 2 0
  3. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    1841 Post(s)
    We have just done the front subframe, wishbones and ARB on an 88 type 85 Coupe, I will post some pics if I get chance. We are lucky in having several quality powder coaters within a stones throw, one new chap I have found (who did the coupe work) was super quick and good.
    0 2 0
  4. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    Pembrokeshire
    22 Post(s)
    yeah, we have one place that does it properly about 30 mins away, which is close round here. they are proper fussy about things and do a proper job. cant get anything else done proeprly mind, if it does the job or looks ok from 10 paces then thats considered fine around here. feckin yocals.
  5. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    1841 Post(s)
    Engineering shops, a dying breed. One local firm left and tiny, I had to send a VR6 block away hundreds of miles to get it bored and 100's in another discretion for balancing and 100 ish in another for porting and valve seats, 5 years ago I could have had it all done locally.
    0 2 0
  6. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    Pembrokeshire
    22 Post(s)
    oh you want to try living out here. in milton keynes i would remove a head and take it to the local engine shop in bletchley. they would sort it out and i would collect it ready to bolt back on. now its a case of using whoever is prepared to do it, although i have found a good place in pembroke who seems keen to do anything to engines. most of the work i now do myself and get the machining done locally.
  7. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    #17
    1841 Post(s)
    It is a sign of the times, engines are so much longer lasting than they once were and when they do break, a rebuild is out of the question financially so it is a used engine or the end for the car. 30 years ago I was doing head gaskets and worn crank rod bearing regrinds on a daily basis, now it is rare work. When a modern engine does break, they are either unrepairable due to manufacturer engineering choices or the complexity exceeds the value of the vehicle.
    1 2 0
  8. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    #18
    Pembrokeshire
    22 Post(s)
    very true. i have just rebuilt a rover v8. bottom end was fine so didnt touch it, bores were fine, so heads off, new timing chain and gears, all new seals gaskets, core plugs. cost me 200 quid and took a day. proper engine. 150 bhp from 3.5 litres. you get that from 1.2 litres today, but nothing warms the heart quite like the exhaust note of a rover v8..
  9. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    #19
    Apr 2015
    Damascus, Syria
    That's a fantastic job you have done....especially as it was a salt corrosion damage. That's a restore job not too many would be prepared to take on,, real labour of love. Well done, I hope that you are rewarded by many more years of pleasurable driving in it.
    1 1 0
  10. Re: Underside, suspension, brakes, bodykit refurb of my 2001 Allroad tdi
    #20
    Nov 2010
    halkirk caithness
    how did you manage to get a new air compressor sheld to fix to your car as mine are all sheered at tyre well
    my allroad also came from skye
  1. Suspension control block/ solenoid/ valve thing 2001 allroad.
    By Tommer9 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-07-2016, 12:50 AM
  2. 2001 A6 allroad suspension....
    Last Post: 07-03-2012, 08:47 PM
  3. 2001 allroad suspension- auto mode
    By richard1360 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2011, 03:42 PM
  4. Allroad brakes and suspension differences
    By WesleyP in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2010, 03:08 PM
  5. bodykit for 2001 passat estate
    By kappapappa in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-06-2008, 10:00 AM
