Thread: Gearbox V6 4motion
Results 1 to 8 of 8
  1. Unhappy Gearbox V6 4motion
    Aug 2016
    No reverse or 1st or 2nd gears. Selector cables all intact but selector lever on top of gearbox will not budge. Looks like selector pin/plate problem? Am in Kent and wonder if anyone can recommend a gearbox repair / reconditioning company that can help me out. Breaks my heart to spend the sort of money I am guessing it will cost me, but the rest of the car is a beaut and it would be a crying shame to scrap or break her.
  2. Re: Gearbox V6 4motion
    Pembrokeshire
    22 Post(s)
    take selector out of box and see if its seized up. if it is, fit a new one. only a few bolts to undo to lift it out.
  3. Re: Gearbox V6 4motion
    Aug 2016
    Can I do this without removing the gearbox from the car?
  4. Re: Gearbox V6 4motion
    Pembrokeshire
    22 Post(s)
    yes
  5. Re: Gearbox V6 4motion
    1840 Post(s)
    Quote Originally Posted by razboy View Post
    The bushes are £1.78 each and you need two...
    Mind you if you snap the rod you need the rebuild kit
    1J0 711 067 L £1.78 x 2
    1J0 711 203 F £28.39
    1J0 711 761 C £12.11
    1J0 711 550 £4.81
    N 908 159 03 £0.54
    This is the similar 0A4 set up which has the same issue as the 02M
  6. Re: Gearbox V6 4motion
    Aug 2016
    Thanks for the info. I disconnected the cables and still cannot move the operating arm. I am thinking it may be the pin has broken from the selector arm inside the box.
  7. Re: Gearbox V6 4motion
    1840 Post(s)
    They do have a habit of doing that, the rivets break off. I do have a low mileage box from a 2001 4M we bought years ago as a spare for our own 4M (now just sold) but the back casing would need swapping over as I had to use it on an A3 quattro which had a cracked case.
  8. Re: Gearbox V6 4motion
    Aug 2016
    An update on this. The car is back from being repaired today. It was a broken rivet on the lower selector fork. Had the garage fit a new clutch while the box was out of the car. Drives beautifully again and I once more have a smile on my face while I am driving.
  1. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  2. 4Motion Gearbox Issues, Leicester
    By Red_Stafford in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2012, 10:21 PM
  3. Golf V6 4motion Gearbox
    By yanman1282 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-03-2011, 07:49 PM
  4. Please Help Mk4 Golf 4motion Gearbox
    By jlx45v in forum Golf MK4 - 1999 - 2004
    Last Post: 13-01-2011, 04:34 PM
  5. Golf V6 4motion gearbox issue
    By julianmachin in forum Chat - Completely Off Topic
    Last Post: 20-12-2006, 08:23 PM
